Rivet chain install
  • gte105u
  • gte105u's Avatar Topic Author
Rivet chain install
29 May 2010 14:44
#371913
Ok, so I am 90% done with my first chain/sprocket replacement and I am stuck. Please, please, oh please help me finish. After making improvised stands, fumbling around on getting sprocket cover off, etc... I got the sprockets replaced. I fed the chain through, got the master link (with rings) in. As I try to put the other side of the master link on, it does not want to go.
So here is the question, what am I doing wrong? How do you get the flat part of the link on far enough to flare the rivet? I am completely stuck. I tried to force it on using pliers but no go. Below is a pic, please help me finish this because I am so very close.
1981 KZ550 A2
  • MFolks
  • MFolks's Avatar
Re: Rivet chain install
29 May 2010 14:58
#371916
A small to medium sized "C" clamp will help a lot. Carefully squeeze the parts together, avoid bending of the plates if possible.
I use a large pair of "Vise Grips" when replacing my 630 chain. 1/4" drive sockets can be used when force is needed on parts sticking through the plates later on.
  • Motor Head
  • Motor Head's Avatar
29 May 2010 15:20
#371918
In your picture, what are those flat shinny pieces of metal? The chain should only have the figure 8 shaped pieces, do you have the clip? It should go on with the solid end in direction of travel, like an arrow pointing so it doesn't hit against something and pop off.
  • gte105u
29 May 2010 15:25
#371920
Those are the spacers for the rivet master link. This is not the kind that has the clip, though I am wondering if I somehow got the wrong master link for a 520 instead (this is a 530 chain). Anyone in the know, does everything look right and I just need to put a clamp on it? I have a 2" c-clamp sitting on the top of my tool box I could break out. Thanks for the help.
1981 KZ550 A2
  • Old Man Rock
  • Old Man Rock's Avatar
29 May 2010 15:47
#371928
I'm with Motor Head on this one, something just not right with that master clip, rivet or C clip, just doesn't seem right...
Maybe it's me....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Kawickrice
  • Kawickrice's Avatar
29 May 2010 15:55
#371932
That square piece does,nt look right. Do you have a tool for the rivet, This is one of the tasks that patience pays off.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Motor Head
29 May 2010 16:19
#371938
Rivot type, still can't see those plate things on any chain. Look at the other links, rivoting should match them exactly.
  • Old Man Rock
29 May 2010 16:58
#371951
"Look at the other links, riveting should match them exactly."... Yes indeed... Regardless of chain pitch, O-ring, X-ring you name it... It should be a rounded end clip...
Is this what came with your chain or you get this somewhere else?
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • PLUMMEN
  • PLUMMEN's Avatar
29 May 2010 17:19
#371956
ive never seen those extra plates before either :S
  • Old Man Rock
29 May 2010 18:04
#371973
Chain Mod anyone??????
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • gte105u
29 May 2010 18:42
#371975
Those rectangle plates slide in and out from the top. I got the rivet pieces as shown above. The directions the chain come with say to put the rectangles in to be sure not to overtighten on the gaskets. It sounds like from the people who know than I here they are not needed? It may make it easier to force the master link on without those being in the way I just did not want to damage anything. Below is a picture I found elsewhere of someone who did it with the spacers in. I think I just need to be more patient with c-clamp and getting it to push on the master link before riveting.
1981 KZ550 A2
  • eddiem
  • eddiem's Avatar
  • KZR FLAG RELAY CARRIER #63
29 May 2010 19:41
#371989
I just got the same chain.
Its a first for me and I was wondering how you put it together without making it to tight,mine did not come with those spacers ????
1976 Kz900
1978 Kz1000
1978 Z1r
1982 Kz1100 A2
1975 Z1b-900
1975 Z1b-900
