I did the 630 to 530 conversion on my 750 LTD
- otakar
Re: I did the 630 to 530 conversion on my 750 LTD
19 May 2010 10:42 - 19 May 2010 10:43
djturnz wrote:
OK OK I'l just STFU, Shiiiish! Must be Wednesday no one has a sense of humor today.
:lol: Thanks Rock, for enlightening me. :laugh:
otakar wrote:
Isn't that What I said in the previous post?? Without all the spaces in between.
I was simply copying the info from the email Z1 sent me.
Besides, it's my thread and I'll re-post if I want to.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 May 2010 10:43 by otakar.
- Ituen
- Rider
19 May 2010 12:47
otakar wrote:
I want a lighter chain and a little more pickup off the line than the stock gearset.
That would depend very much on what you are trying to achieve with the conversion. Why are you doing it?
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- otakar
19 May 2010 13:02 - 19 May 2010 13:05
OK that changes things around the other way. You want a larger rear sprocket. Than go with a 15t Front and a 42 Rear. That is a 2.80:1 ratio and is a good pickup ratio. That should even be geared enough for wheelies, and the chain will not ware out as quick as it would with a 13t front. You can also still use the same length chain.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 May 2010 13:05 by otakar.
19 May 2010 13:23
- Ituen
- Rider
19 May 2010 14:01
I don't want to wheelie, I just want to leave the line HARD. Maybe I should run a 15T front and a 36 or 38 rear.
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- dejavoodo41
19 May 2010 15:56
I'm not sure exactly what I'm running on mine but I do know that it is equivalent to stock in front and 2 up in the rear. With this setup 5K rpm is right at about 70 mph. When I want to pass I just give her a good twist. Mine was a real pain finding the rear sprocket because the PO somehow managed to install what appears to be an 80's ZX-10 drive hub and cush drive in a concours rear wheel. I've been running this setup for about a year and am really happy with it.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- dejavoodo41
19 May 2010 16:40
- djturnz
20 May 2010 07:51
otakar wrote:
My smilie meant I was kidding too. Text sux for sarcasm.djturnz wrote:otakar wrote:
OK OK I'l just STFU, Shiiiish! Must be Wednesday no one has a sense of humor today.:lol: Thanks Rock, for enlightening me. :laugh:
1982 KZ750 (4) LTD
- otakar
20 May 2010 08:54 - 20 May 2010 09:01
I know I got the gist, I just threw it right back at-cha
:kiss: OMR just likes to bust my chops in PMs. I just thought I would bring his humor public. I hope that during all of this BS, we are actually able to help you. You want better cruising someone els wants better take off. Sometimes it just gets confusing on who you are attempting to communicate with at the moment. The point is that on the 650/750 the sprocket ratio is about at its optimal from the factory due to available HP from these mid size motors. Because the 750 is a more modern motor that has about the same HP as the old 900 had, a bit more can be done with it in both directions. The 750 has a bit less torque but a bit more available RPM than the old 900. This means that getting take off performance is a bit easier than getting cruising performance. I believe that if you keep the sprocket ratio between 2.4:1 and 2.8:1 things will be perfectly OK. Obviously 2.4 will give you cruising and 2.8 will give you takeoff. I believe that a SLIGHT deviation from those #s can also be allowed
Since they are only based on op pinion which is based on experience. You know what they say about opinions, "they're like A** Holes, Everyone's got one".
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 May 2010 09:01 by otakar.
- otakar
21 May 2010 14:10
Soooooo- what did you decide on?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- djturnz
23 May 2010 15:41
531blackbanshee wrote:
I tried to find the pliers and wire locally. Nobody caries them. I guess I'll have to order them.
1982 KZ750 (4) LTD
