Forwards and back play in rear wheel.
  • Krusty_47
  • Krusty_47's Avatar Topic Author
22 Apr 2010 10:17
#362357
I have a KZ900 with Drum breaks on the rear. I have about 1/4 in play in the rear wheel before it stops moving or moves the chain. The rear sprocket does not move just the wheel itself.
I have yet to tear into it to take a look at it but I was going to ask if that could possibly be caused by bad Shock Dampers? If not that what could be causing this?
If I need to replace the rear wheel its not a problem just need to find one.
Any information you have would be greatly appreciated.
1976 KZ900 A4
1980 KZ1000 G1
  • MFolks
  • MFolks's Avatar
Re: Forwards and back play in rear wheel.
22 Apr 2010 10:39
#362363
I'd pull the rear wheel out and check the bearings and rubber "Cush" drive.
www.goallballs.com sells replacement bearings.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
22 Apr 2010 10:55
#362369
Normal wear and tear...
What MFolks said.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Krusty_47
22 Apr 2010 11:22
#362380
Alright I will do that at some point before I go ordering parts like crazy next Friday.
Thanks a lot.
1976 KZ900 A4
1980 KZ1000 G1
  • otakar
  • otakar's Avatar
22 Apr 2010 12:07
#362395
I would definitely fix the problem before you ride the bike. ANY movement in either of the wheels can KILL you. This is no laughing matter. Weather you have movement in the wheel bearings or the swing arm bearings, both situations are potentiality deadly.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Krusty_47
22 Apr 2010 12:22
#362398
Well I guess I should be specific so people don't get the wrong impression.
The movement is in the rotation of the wheel. I know the wheel should not move at all when the chain is locked in place. Even with the chain locked in place I can move the wheel freely for about 1/4 in work of travel.
The wheel does not wobble side to side or move forward and back if you shake the wheel. All extra movement that shouldn't be there is all in the rotation of the wheel.
1976 KZ900 A4
1980 KZ1000 G1
  • otakar
  • otakar's Avatar
22 Apr 2010 12:57
#362408
WELL that makes a big difference. That movement is absolutely normal on older bikes. That is just ware in the rubber cushions that connect the drive hub to the rear wheel. If it annoys you there are two ways you can fix that. The correct way which is also the expensive way is to replace the cushion(s). Since you have a 900 they should be separate but are sold as a set. This will cost you about $50
www.z1enterprises.com/detail.aspx?ID=22
Or you can put rubber shims into the gaps, that you can cut from an old inner-tube.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • RonKZ650
  • RonKZ650's Avatar
22 Apr 2010 12:57
#362409
There is a rubber damper thing on the wheel that the sprocket mounts into. Play is no big deal, I don't see any need to worry at all.
  • Krusty_47
22 Apr 2010 13:18
#362417
50 bucks is nothing compared to everything else I need to pick up to really get my bike running like a champ.
I will probably replace the bearings and maybe have someone do the spokes for me. But the spokes can wait till I need new tires.
1976 KZ900 A4
1980 KZ1000 G1
22 Apr 2010 14:49 - 22 Apr 2010 14:49
#362434
Can hardly wait to hear later report if newly installed dampers allow same 1/4" wheel movement. :ohmy: :laugh: :laugh:
Good Fortune! :)
Last edit: 22 Apr 2010 14:49 by Patton.
  • Krusty_47
22 Apr 2010 15:42
#362443
Well how is that at all helpful Patton? :-D
1976 KZ900 A4
1980 KZ1000 G1
22 Apr 2010 16:06
#362447
I can't speak for Patton, but I also would like to know if replacing the cush or "shock damper" with a new one eliminates the play. This would be good info for all of us who have that 1/4" of play because if a new damper results in the same play perhaps we should not use shims/whatever to eliminate it. Personally, I'm betting there is still play with a new damper; the question is "how much?" Ed
