Forwards and back play in rear wheel.
  • otakar
  • otakar's Avatar
Re: Forwards and back play in rear wheel.
22 Apr 2010 17:59 - 22 Apr 2010 18:01
#362473
If you have a fresh cush drive your play should be about 1/16" or less. That is about what I have on my GPz1100 with a 29 year old cush.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 22 Apr 2010 18:01 by otakar.
  • timebomb33
  • timebomb33's Avatar
22 Apr 2010 18:03
#362474
i have almost a 1/2" of slop in my cush drive in my little drag bike i use that to slow my reactions . sometimes it even works.
I THINK MY POWERBAND BROKE
  • polkat
  • polkat's Avatar
22 Apr 2010 21:46 - 22 Apr 2010 21:47
#362525
I have about 1/4" in my KZ750H3. It has never bothered me and has never gotten worse. But, that said, does anyone have a pic of what it looks like in there? Trying to figure how shims would be installed.
Last edit: 22 Apr 2010 21:47 by polkat.
  • MFolks
  • MFolks's Avatar
22 Apr 2010 22:16
#362529
Kinda looks like a thick legged rubber spider designed to fit in the openings of the wheel between the rear sprocket carrier.
  • Bluemeanie
  • Bluemeanie's Avatar
23 Apr 2010 05:59
#362553
Heres one for a 650 but you get the idea. :)
  • otakar
  • otakar's Avatar
23 Apr 2010 06:49
#362569
On the 900 those units are individual and they snap into the pockets with little "nubs". To shim old dampers, all you have to do is to take the sprocket drive hub and on the protrusions that go into these dampers just glue rubber from an old inner tube around each casting. Than just insert normally. It will depend on how warn the old dampers are.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • polkat
  • polkat's Avatar
23 Apr 2010 13:10
#362640
Hummm...kinda looks like a designer chocolet donut! It's clear what it does, but why did Kawa consider it necessary?
  • MFolks
  • MFolks's Avatar
23 Apr 2010 14:11
#362654
It absorbs the "snatch" when shifting gears making the power transmission from the engine to the drive system somewhat smoother.
  • timebomb33
23 Apr 2010 19:24
#362740
and keeps the clutch basket or gears from breaking under hard launches. thats the idea anyway.
