KZ440B Front Sprocket Torque Setting
  • pjed
  • pjed's Avatar Topic Author
03 Apr 2010 13:34
#358192
Can anyone tell me what the torque setting is for the nut holding on the front sprocket? My bike is a 1980 KZ440B. Thanks!
1976 KZ400 D3
2008 Kawasaki Ninja 250 (sold)
2005 Kawasaki ZX6RR (sold)
2013 Harley Davidson 883 Iron
  • PLUMMEN
  • PLUMMEN's Avatar
Re: KZ440B Front Sprocket Torque Setting
03 Apr 2010 15:10
#358204
a breaker bar with 10' cheater pipe snugs em up nicely B)
  • pjed
03 Apr 2010 18:12
#358244
Don't really want to overtighten it. I thought 70ft/lbs would be enough but that seemed too easy.
1976 KZ400 D3
  • RonKZ650
  • RonKZ650's Avatar
03 Apr 2010 19:31
#358259
The official torque figure is "as tight as you can wrench it on".
  • PLUMMEN
  • PLUMMEN's Avatar
03 Apr 2010 19:40
#358263
if you ever experiance one coming off going down the road youll realize it can never be too tight,and dont forget red locktite ! :laugh:
  • bountyhunter
  • bountyhunter's Avatar
03 Apr 2010 21:29
#358281
I think mine is spec'd at 100 ft-lbs, and I also use blue loctite.
  • pjed
04 Apr 2010 15:44
#358408
Thanks guys. I put on some red loctite and torqued it to 100 ft-lbs.
Got the wheels off and will be replacing the bearings. Anyone know the front and rear axle torque settings off top of their head?
Thanks!
1976 KZ400 D3
  • ELCouz
  • ELCouz's Avatar
04 Apr 2010 18:49
#358447
. I put on some red loctite...
Won't that be PITA to remove the next time you change the sprocket (red loctite needs a lot of heating to be released if i remember)?
Just my 2 cents
Laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
  • PLUMMEN
  • PLUMMEN's Avatar
04 Apr 2010 18:57
#358449
ask omr what its like loosen the nut on your sprocket,then picture your wheel locking up at 60mph.
red locktite beats red blood on the ground any day in my book! :laugh:
  • bountyhunter
04 Apr 2010 21:13
#358475
The Kawis have a splined flat washer that you flatten against one flat of the nut so the nut can't come off. When I changed mine, the nut was loose but held in place by the lock washer.... hence my cleaning it thoroughly and using blue loctite. I don't recommend red unless you want to use a torch to remove it.
  • MFolks
  • MFolks's Avatar
04 Apr 2010 22:21
#358481
Thread Locking Compounds:
Loctite #222MS PURPLE, low strength thread locker
For screws under ¼”.
Loctite #242 BLUE, Medium strength thread locker
For ¼” to ¾” bolts.
Loctite # 262 RED, High strength thread locker permanent
For up to ¾” bolts (can be loosened by 300 F heat).
Loctite #271 RED, High strength thread locker for sealing plugs, nuts and bolts (can be loosened by 300 F heat).
Avoid using any of the thread lockers on plastic fittings as it will quickly "Craze" or crack them.
  • PLUMMEN
  • PLUMMEN's Avatar
05 Apr 2010 05:42
#358499
what happens when the little tab breaks off the washer? :S you find the sprocket and chain balled up inside the housing tearing things up,yes it happens B)
