Fork Baking Question
  • T_Dub
  • T_Dub's Avatar Topic Author
Re: Fork Baking Question
19 Mar 2010 16:55
#354620
But are they bakeable Tim? If so I'll tell him to leave them in.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • timebomb33
  • timebomb33's Avatar
19 Mar 2010 18:02 - 19 Mar 2010 18:03
#354646
i don't know i just usally bake cookies, not bearing material i think they are a lead babbit material and it doesn't take much heat to melt lead i'd be nervous myself why don't you just paint them instead. i know if you leave steering head bearings in a frame that is being powdercoated it will kill them. so i wouldn't imagine these would hold up any better. 450 is a lot of heat that is for sure. and that kind of heat will do wierd things to metal
I THINK MY POWERBAND BROKE
Last edit: 19 Mar 2010 18:03 by timebomb33.
  • trianglelaguna
  • trianglelaguna's Avatar
19 Mar 2010 18:07
#354649
coat em in butterscotch and sprinkles first
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • testarossa
  • testarossa's Avatar
19 Mar 2010 18:16
#354655
Lead melts at 800deg. Try and be constructive.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • trianglelaguna
19 Mar 2010 18:23
#354660
and lemon too
1976 KZ900
2003 ZX12R
2007 FZ1000
  • PLUMMEN
  • PLUMMEN's Avatar
19 Mar 2010 18:47
#354667
i got baked once while painting some dirtbikeforks in an unvented garage as a kid,does that count? :laugh:
  • rgoot01
  • rgoot01's Avatar
19 Mar 2010 20:20
#354711
If in doubt take it out. I have to agree with timebomb, If the material is questionable, than paint the legs if you can't remove or replace the component. Granted p-coat is more durable, however durability means nothing if the leg or component is ruined in the baking process. Have you looked into Dupont Imron paint. I used a lot of this when painting industrial and heavy equipment. It is Mil-spec'd and damn near as durable as long as you put several coats on.
Rob
Salida,CO
  • testarossa
19 Mar 2010 20:26
#354713
Good call on the Imron. I forgot about that stuff. Works pretty good on the bottom of speedboats and airplanes. Ought to hold up on fork legs.
2004 ZX-10R
Angola, IN
  • rgoot01
  • rgoot01's Avatar
19 Mar 2010 20:30
#354717
Absolutely! Great stuff to use when durability is a factor if p-coat isn't an option.
Rob
Salida,CO
  • trianglelaguna
19 Mar 2010 20:31
#354718
why bake somthing where there is even a question if it will melt or make it brittle...it is on the inside so it will fail blind one day....not gonna kill you but it will screw the forks up..read::: scar
1976 KZ900
2003 ZX12R
2007 FZ1000
  • KawiConvert
  • KawiConvert's Avatar
20 Mar 2010 12:08
#354901
Use a different powder coat (er). The power used on my frame cures at 375 for 20 min. Works fine and is that much farther from the limit of 500.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
  • T_Dub
20 Mar 2010 13:41
#354913
He coated his from his SR and said they look fine, I'm gonna tell him to go ahead, I was already thinking about getting B1 forks anyways, if he ruins them then I will.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
