Gauge restoration decals
Re: Gauge restoration decals
17 Feb 2010 05:39 - 17 Feb 2010 05:44
#348756
Galactica wrote:
I've taken apart the speedo from a 650 I had as a donor. It takes a lot of patience to pry apart the chrome bezel without damaging it too badly. It takes even more patience to re-crimp it without leaving marks. Also if you want a really flawless job it would take practice on several units. After I had re-crimped it I noticed that it was not square all the way around. Most people wouldn't even notice....
Here's the Z-Resto link provided at Z1E
www.z1enterprises.com/reference/ZResto_custom_work.aspx
In an earlier thread
kzrider.com/index.php?option=com_kunena&...d=4&id=117000#117010
duncan wrote:
i've taken the tach apart but not the speedo. it's real easy if you use a dremel to cut the chrome ring, and then some jweld and hose clamp to cement it back together.
apeman wrote:
The old article suggests removing the band around the gauges by levering it up from the underside. I have found that results in too much damage to the band to make it look good after it is put back on, and crimped down. Therefore, I instead took a dremel with a cut-off wheel to the band, and sliced through it, being carefull not to damage the gauge cover. Then I slipped off the band, and did my gauge clean-up. To reinstall, I assembled the cover onto the gauge, slipped the band on, and held it tightly in place with a rubber band. Then I placed a drop of JBweld epoxy onto the gap in the band, and let it dry. (Make sure you mount the gap in the band at an location that will not be readily visible when the gauge is remounted onto the bike.) That has been working well for over a year.
Good Luck! :)
Last edit: 17 Feb 2010 05:44 by Patton.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
18 Feb 2010 06:45
#348949
That's a great tip for removing the band!
I've had my speedo apart to evict a Spider, uncrimping the band all the way around.
What a pain in the a$$.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • otakar
  • otakar's Avatar
18 Feb 2010 07:46
#348969
OK-After some testing, I have come up with this very easy way of harmlessly and easily removing the markings on your gage face. This will be a picture presentation so be patient.
First apply my solution to the surface which you want to remove the markings from. The solvent dries very slowly so evaporation is not a factor. Also odor is not a factor. Apply a liberal amount of the solvent to the gage face with a Swab, making sure that there is a pooling of the solvent and allow to sit for about 5 minutes. You may apply more if it starts to dry out on you.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
18 Feb 2010 07:49
#348970
After the five minutes, use the swab and rub the area to loosen any dry spots. This should not take much effort.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
18 Feb 2010 07:51
#348972
Wipe off area with bathroom tissue. This solution is water soluble, so any mess you make can easily be wiped up.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
18 Feb 2010 07:51
#348974
Finish wiping surface.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
18 Feb 2010 07:53
#348975
Reapply clean solution to area.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
18 Feb 2010 07:54
#348977
You may wipe this off immediately.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
18 Feb 2010 07:56
#348978
Apply a small amount of solution to clean peace of bathroom tissue and wipe off area by rubbing between your fingers.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
18 Feb 2010 07:57
#348979
Your gage face is now ready for a decal.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
  • otakar's Avatar
19 Feb 2010 06:56
#349150
kenskz1000 wrote:
Has anyone used the gauge face restoration decal that Reprodution Decals carry? They are 24 dollars for the pair. I could not post pictures for some reason, could someone please post. This looks like a great winter project
Hi Ken
I sent out the "Face remover" to you let me know what you think after you use it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kenskz1000
  • kenskz1000's Avatar Topic Author
19 Feb 2010 15:08
#349202
I am sending out my part in the morning. Thanks
