Gauge restoration decals
- kenskz1000
15 Feb 2010 14:55
Has anyone used the gauge face restoration decal that Reprodution Decals carry? They are 24 dollars for the pair. I could not post pictures for some reason, could someone please post. This looks like a great winter project
Re: Gauge restoration decals
15 Feb 2010 15:19 - 15 Feb 2010 15:25
Some info and pics in this link.
Click here> www.reproductiondecals.com/default_frame...info_instr.html~main
Then scroll down and click on Restoring Gauge Faces - Back Lit Meters.
Another alternative > www.z1enterprises.com/reference/ZResto_home.aspx
Good Luck!
Good Luck!
Last edit: 15 Feb 2010 15:25 by Patton.
- otakar
15 Feb 2010 17:37 - 15 Feb 2010 18:09
Thanks for the find. I have been on their sight many times but gave never noticed those. I wil get a set to try on my GPz spedo. While reading the article, I figured with my knowledge of solvents and my supply of same, I ought to figure how to wash the face off without having to sand it. Also obviously without damaging the plastic. Low and behold I have figured it out and it makes things so much simpler. Take a look at a HALF washed gauge face.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 15 Feb 2010 18:09 by otakar.
- otakar
15 Feb 2010 18:11
Notice the "x1000r/min" which is molded into the plastic.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
15 Feb 2010 18:18
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
15 Feb 2010 18:19
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
15 Feb 2010 18:20
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kenskz1000
16 Feb 2010 16:24
Thanks for posting pictures of decals, some day i will be able to. What solvent did you use?
- otakar
16 Feb 2010 17:38
It is a blend of "Propylene-Glycol-Ether", "Butyl-Alcohol" and "Dimethyl carbinol". I can send you a small bottle if you wish. It is a water miscible solvent so you can wash everything off with soapy water at the end. I would ware latex gloves if you plan on getting it on your skin, because it will really dry your skin out. Otherwise it is relatively low in toxicity.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- 79MKII
- Love Them Kaws!
16 Feb 2010 19:00
Great info on stripping the old faces and also nice decals.
Have you guys found a source for the band around the gauges or how to reclamp the old ones? That's the part that concerns me...
The Kaw List:
- otakar
16 Feb 2010 19:36 - 16 Feb 2010 19:39
I believe that Z1E has them.
Gauge Covers Chrome Top (pair) Kawasaki
EM58-12410
EM58-12410
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 16 Feb 2010 19:39 by otakar.
- Galactica
16 Feb 2010 21:37
I've taken apart the speedo from a 650 I had as a donor. It takes a lot of patience to pry apart the chrome bezel without damaging it too badly. It takes even more patience to re-crimp it without leaving marks. Also if you want a really flawless job it would take practice on several units. After I had re-crimped it I noticed that it was not square all the way around. Most people wouldn't even notice. I haven't seen their work, but it might be worth it to send it to Z1E for a good restoration.
Also if you want your units, speedo and tach, to be fairly accurate, I believe Z1E can calibrate them fairly closely.
77KZ1000
76 KZ900
76 KZ900
