Sprung solo seat mounting?
- polkat
10 Jan 2010 20:34 - 10 Jan 2010 20:43
I'm planning to mount a spring type solo seat on my chopped KZ750H3. Not sure how to do this (though I have some ideas). I'd prefer to do it without welding. The seat section of the frame is stock. Has anyone here done this, and how did you do it? Thanks!
Last edit: 10 Jan 2010 20:43 by polkat.
- Capt806dfd
Re: Sprung solo seat mounting?
11 Jan 2010 05:14
I am also using a spring solo on my kz650 but it will be welded, while searching for the hardware I did come upon bolt on mounts on ebay. I just searched solo seat mounts under the motorcycle parts tab. Hope this helps.
Andy
Andy
- Bdog
- Sweep the leg johnny!!!
13 Jan 2010 12:15
www.tcbroschoppers.com
They have either a bolt on or weld on type solo, may be what you're looking for.
Brandon
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
