81 kz650 petcock
  • Beater650
  • Beater650's Avatar Topic Author
81 kz650 petcock
28 Dec 2009 17:35
#340989
Hey folks this is my first post and i'm not too sure where to put it, but I saw a gas tank post so I figured i'd post my question here. I have an 81 kz650 i'm not sure what model designation it is (f1 h1). I rewired the bike using a diagram I found on kzrider and the bike turns over. Now I need to figure out my fuel situation. This one came with a vacuum advance petcock I think and the PO said it needed to be rebuilt, but I was wondering can I just run a straight feed petcock and not have to worry about vacuum lines and leaks. If so where can I purchase one locally? This is my first build and i've never had any experience with motorcycles. Your help is appreciated thank you.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: 81 kz650 petcock
28 Dec 2009 17:50
#340992
Welcome.
The petcock has a prime position and you can run the bike on this position. Just make sure the vacum line that goes to the carb boot has not been removed so that air goes into the boot.
There should be three lines. Two for carbs and one to operate the petcock.
There will be some 650 riders that will help you out. Roy
  • Beater650
28 Dec 2009 18:00
#340993
Yeah thats another one of my problems. The PO removed all the fuel and vacuum lines so I am kind of clueless to what goes where. Thanks for the quick replay.
  • anarki650
  • anarki650's Avatar
28 Dec 2009 18:49
#341001
The fuel line hooks to the larger inlet between the #2 and #3 carbs (right in the middle) on the fuel rail. The vacuum line from the petcock should go to a nipple on the #2 carb (from the left as you are sitting on the bike, second one in from the petcock side). This nipple is closer to the inside of the carb body on the outside of the carb. There are two nipples that look exactly like the vacuum nipple that are really close to the fuel rail on the #2 and #3 carbs also, these are atmospheric vents, not vacuum ports. These came with hoses on them that ran up toward the airbox stock, I've always run them open to atmosphere with no ill effects. Someone here will likely post a pic with these things labeled, I forget who the member is with the pic, but it's really helpful if you have a hard time following my ramblings!!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • JMKZHI
  • JMKZHI's Avatar
28 Dec 2009 21:33 - 29 Dec 2009 07:31
#341023
If your bike is a CSR, then it would be the H1 model.
When using a manual fuel valve, fuel has a tendency to leak past the float needle valves when the bike is off, so you'll have to be diligent in setting it to the OFF postion. I prefer the vacuum petcock. K&L rebuild kits should be available at Z1Enterprises.com.
(K&L parts are made in Japan & oem quality - my experience anyway).
I believe Z1 sells a Pingel/DragSpecialties fuel valve; you'll need the 34mm adapter plate. The fuel tank orifice will need to be reamed out a tad to accept the fuel screen.
Caution: sparks could cause an explosion. The vacuum port is the forward nipple on the #2 carb. The rearward port is a vent & the #4 carb has a vent port in the same location.
PS: I have a new Pingel/DragSpecialties fuel valve & the adapter plate (also new) for the 81 CSR that I will not be using. I'm looking to sell both items. Send a pm if interested. Thanks.
Last edit: 29 Dec 2009 07:31 by JMKZHI.
  • Beater650
29 Dec 2009 07:27 - 29 Dec 2009 08:10
#341059
Here is a picture of the carbs, the PO said he rebuilt them, but didn't run it.
Here is a some pics of the petcock, it appears to be missing a fitting.
i46.tinypic.com/289dc1d.jpg
Here is a picture of the gas tank. Is this usable or will it need to be treated?
i45.tinypic.com/2nt8rjn.jpg
Last edit: 29 Dec 2009 08:10 by Beater650.
  • Beater650
29 Dec 2009 08:17
#341072
Some of the pictures worked some didn't, oh well.
  • JMKZHI
  • JMKZHI's Avatar
29 Dec 2009 09:45 - 29 Dec 2009 18:54
#341074
Did he mention anything about rejetting the carburetors for the pod filters? Whatever he said...
Don't believe anything the previous owner told you.
That fuel valve is not stock for the 81 650-CSR.
Last edit: 29 Dec 2009 18:54 by JMKZHI.
  • Beater650
29 Dec 2009 09:47
#341076
Yeah, he said he had rebuilt and rejetted the carbs when he had it apart and that was the petcock that came off the gas tank.
  • Beater650
29 Dec 2009 09:49
#341077
He said once he did the carbs and had it running he saw the harness and how burnt out it was and decided to rewire the whole bike. He ended up finishing up the rewiring, but it was just a twist and electrical tape type rewire so I tore it all out and did my own with solder.
  • JMKZHI
  • JMKZHI's Avatar
29 Dec 2009 10:12 - 29 Dec 2009 18:55
#341083
Since the bike has pod filters, it should be a simple matter to remove the carbs & have a look inside.
Remove the float bowls. You should be able to read a number that's on the main jets. Stock is 92.5 (81 650-CSR). I don't know what size is needed for the pods.
If the bike has an aftermarket (4-into-1) exhaust system, the jets should be sized for that as well.
Last edit: 29 Dec 2009 18:55 by JMKZHI.
  • Beater650
29 Dec 2009 11:21 - 29 Dec 2009 11:22
#341090
I'm assuming a brass fitting is supposed to go there for the fuel line and the one on the back is a vacuum line. Where would I be able to get a brass fitting for that? Home Depot maybe? I'd like to get this one to work as I just want to see if the old girl will fire up.
Last edit: 29 Dec 2009 11:22 by Beater650.
