Mono shock mounting
- Bdog
- Sweep the leg johnny!!!
Mono shock mounting
23 Dec 2009 17:32
I have searched, but I know you guys are a very proud of you rcreations, and pic whores every one. So I propose that those with the monoshock conversion mod done to their bikes should post up and get a good reference for those who want to but haven't yet. One of those fellas is me, the one that wants to but hasn't yet. So I leave it to you masters of the mods, dazzle us!
Brandon
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- kzstreetfighter71
- Atlantic West Coast
Re: Mono shock mounting
23 Dec 2009 18:48
- kzstreetfighter71
23 Dec 2009 18:49
- bobberboy
23 Dec 2009 21:04
I like this. I kind of thought of looking into wether or not it was to do this or not. But my main question is if it is possible to do this with a stock swing arm. If not, what bike has a swing arm that will mount right up to my 1980 KZ 650E?
- kzstreetfighter71
24 Dec 2009 07:10
the 2000 to 2004 gsxr 600 and 750 swingarm is a good choice but there is no easy ways to make it work, besides having to fab and weld in the shock mount you will have to have an oversized sleeve machined for the axle as they are going to be different sizes, you will then need to relocate your battery box because the shock mount will be in the way, then a bit of bracing will be needed and ontop of all that you will need an offset sprocket, add that to the cost of a gsxr wheel, tire, break and chain?:blink:
- Old Man Rock
24 Dec 2009 08:05
Here's how I did mine...
NOTE: at the time of writing, the top mount 3 leg support wasn't completed...
kzrider.com/index.php?option=com_docman&...d&gid=430&Itemid=108
Here's the completed better (3 legged & plate) support...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Mark Wing
24 Dec 2009 18:46
Here;s the upper shock mount on a cross bae I added
and if you look closely you can see the linkage mount on the center stand cross bar
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- schmol
28 Dec 2009 03:49Please Log in or Create an account to join the conversation.
- Bdog
30 Dec 2009 14:23
I like how almost everyones mounts are different. This is why I had to ask this question.
Mark, is that DOM or HREW/CREW tubing? Old piece of frame?
What thickness steel is everyone using?
What, if any, other considerations were there for the frame (i.e. extra bracing)? If any, where?
Thanks for the input and if there are others, please chime in.
Brandon
Brandon
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- thompsonmx100
30 Dec 2009 15:46
I started with a mono shock so half the work was done for me but i fitted an 05 gsxr 750 swingarm to my gpz. I had to use the swingarm pivot sleeve from the gpz and just slid it into the gsxr sleeve. I can use the original pivot bolt. For the side to side I had to get 4 more spacers that the gsxr already uses. two on each side and that part is done. The trick is to get the geometry right. You have to mount the shock in a way that it is in the same position as it was on the original bike. I.E. the shock angle and height.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- Mark Wing
30 Dec 2009 18:07
Bdog wrote:
On my bike I used a piece of chrome molly tubing that was pretty thick and the tabs I picked up at the local metal yard.
Mark
Brandon
Mark
Yorba Linda Cal.
Yorba Linda Cal.
