Lost right side engine points cover on kz750
  • sakiguy
  • sakiguy's Avatar Topic Author
23 Dec 2009 16:45 - 23 Dec 2009 16:50
#340434
Not sure what this side cover is called. I was riding today and noticed it wasn't there any more :woohoo: ! Not sure if it fell off or what. I'm guessing it was loose and it fell off while riding. Doesn't appear to be the stator cover, or the generator cover...so I think it's called the engine inspection cover? Any how, this seems hard to find even on ebay for the time being. Thinking maybe find a junky looking part and match the paint. Is there a place where you can buy oem paint? Bah, this is upsetting but crap like this happens I guess. I must of loosened it and forgot to tighten it. Any how, let me know where I can find this part for cheap if possible. Thanks.
Edit: It's the points cover.
1983 KZ750 N2 Shaft
Last edit: 23 Dec 2009 16:50 by sakiguy.
  • jordan
  • jordan's Avatar
Re: Lost right side engine points cover on kz750
23 Dec 2009 17:05
#340436
cgi.ebay.com/ebaymotors/IGNITION-COVER-K...?hash=item53de54075f
That is an ignition cover. lots of them on ebay. 650 cover will fit also, not sure if or what others are compatible
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • anarki650
  • anarki650's Avatar
23 Dec 2009 17:06
#340437
I'm pretty sure those are the same as on the kz650 (share most of the bottom end in common) and the pic looks like like it is.
I should have an extra one in my garage, probably not in perfect shape, might have a little rash on it (been awhile since I looked for/at it). Let me run out and peek for it and I'll post up if/when I find it. If I have one it's yours for the cost of shipping. Merry Xmas!
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • thompsonmx100
  • thompsonmx100's Avatar
23 Dec 2009 17:10
#340438
I have one too. I can check on its condition. Was your polished?
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
  • sakiguy
23 Dec 2009 17:15
#340439
Hey thanks I appreciate that if you happen to find it. There appear to be some cheap options on ebay. I was limiting my search to kz750 covers as well. I think my only issue would be finding the paint to match the gold paint of the spectre.
1983 KZ750 N2 Shaft
  • sakiguy
23 Dec 2009 17:18
#340440
No mine was the I guess you would call it 'gold' color found on the 82-83 kz750 spectre. I'm afraid I might have to wait for a spectre cover though to come up on ebay since I think it will be hard to color match the engine paint.
1983 KZ750 N2 Shaft
  • kawsakiman
  • kawsakiman's Avatar
23 Dec 2009 20:54
#340475
let me play devil's advotcate here.
HOW THE HELL DID YOU LOOSE IT?
i also have one but i really want to know first how the hell it just " fell off? "
i mean wtf? you did tighten it right? the bolts just don't back off on their own.
i'm not trying to pick on you boss but come on! this is first year stuff.
  • JMKZHI
  • JMKZHI's Avatar
23 Dec 2009 22:21
#340479
It might be a good idea to remove the timing advancer and clean & lubricate it, since it might have collected some road grit n stuff. I wouldn't ride the bike until a replacement pulsing coil cover is installed. Get one from a 750-4 asap - worry about getting a Spectre cover later.
PS: it's doubtful that yer gonna be able to color match one.
  • MFolks
  • MFolks's Avatar
23 Dec 2009 22:48
#340483
When you get the replacement cover and bolts, use some Blue Loctite #242 to keep the bolts tight. Do not use any Red Loctite as it needs about 350 F heat to loosen up(more than the pulsing coils can stand).
The Blue Loctite is removable with tools,but won't vibrate loose.
  • sakiguy
24 Dec 2009 03:54
#340490
Yah, I have beaten myself up for this the whole day. This was my blunder. I think I left the bolts loose on the cover. I'm just going to find a real cheap one so that I can cover it, then just keep looking for a worthy replacement part. Looks like the kz440 covers even work.
1983 KZ750 N2 Shaft
  • sakiguy
24 Dec 2009 04:16 - 24 Dec 2009 04:16
#340494
No thanks asshole. Yes, people make mistakes. I'd rather not dwell on it though! You are not playing devil's advocate, you are just being a complete ass.
1983 KZ750 N2 Shaft
Last edit: 24 Dec 2009 04:16 by sakiguy.
  • loudhvx
  • loudhvx's Avatar
24 Dec 2009 04:28 - 24 Dec 2009 04:30
#340495
The ones from an electronic ignition 550 should also fit.
From what I remember, yes, the ones from a 650 will fit on as far as mating with the engine, but if I recall, the covers from a bike with points may not stand out as far as the ones from a bike with electronic ignition. This means there's a chance the electronic-ignition may come into contact with the low-profile points covers. Make sure you get one from any KZ500/550/650/750-4 with electronic ignition.
Last edit: 24 Dec 2009 04:30 by loudhvx.
