Sprocket alignment?!? 630-530 conversion
- otakar
Re: Sprocket alignment?!? 630-530 conversion
20 Nov 2009 19:42 - 21 Nov 2009 05:51
. They attempted to do that to us here in the US also about the same time but we were too dense to comprehend it. i have no problem with it since I am Czech in origin. :lol:
The sprocket on the left is a 530 (15.875mm) pitch, and the one on the right is a 630 (19.05mm) pitch.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Nov 2009 05:51 by otakar.
- otakar
Re: Sprocket alignment?!?!?!?!
20 Nov 2009 19:48 - 20 Nov 2009 19:50
Out of curiosity. Where did you get the spacer to begin with??? By the way what are you doing up at this time. It is 0345 in England.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Nov 2009 19:50 by otakar.
- otakar
20 Nov 2009 19:53
My-Badd. I noticed you're in Martha's Vineyard MA. It's only 2300 there now.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kano
- Not Another Bloody Limey!
20 Nov 2009 19:58
spacer was on dymag wheels when i bought them used from a salvage yard in 1990.
- thompsonmx100
20 Nov 2009 21:13
Just out of curiosity how did you end up with this sprocket. It seems to me that you shouldn't need to have an offset sprocket to just step down to a 530
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- kano
20 Nov 2009 21:17
well for me i went from a 4.25 rear wheel with a 130 tyre
to a 6.00 rear wheel with a 180 rear tyre hence the offset
went to a 530 chain and sprocket becouse im running gsx-r 02 rear end,
- otakar
21 Nov 2009 04:10 - 21 Nov 2009 05:50
Because that is the only 530 sprocket with the proper inner spline that I could find, and it was the sprocket recommended by "Z1" as the one required for the conversion. The "J" motors use a Z-12 spline, unlike the older bikes which use a Z-13 spline. What I require is a replacement 17t front sprocket for a Kawasaki police bike p21-24 no one shows a sprocket of that type. JT leaves that replacement blank. They have rear sprockets but not front ones. Z1 also conveniently leaves those models out of their search engine. SunStar also conveniently skips those models, and the part# conversion for that sprocket. The ZR1100 and the ZX11-ZX14 have sprockets that have the 12 tooth spline but the dimension is .2mm larger. This would leave the sprocket loose on the shaft and destroy the shaft rather quickly.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Nov 2009 05:50 by otakar.
- otakar
21 Nov 2009 05:49
If anyone knows of a place that has a selection of front sprockets for the 2002-2005 police bikes, this would make life much simpler.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
21 Nov 2009 07:26
Well guys, after extensive research, I have found the proper front sprockets. Made by "Sprocket Specialists". They make the 12t 28.5mm spline with the proper offset, 530 sprockets. They make them in 15,16,17,18 tooth. This will now make the chain / sprocket alignment much easier. Now, to see if Z1 will exchange the proper sprocket I require for the wrong one I bought from them? The sprocket I require is a 635 series, 17 & 18 tooth.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
21 Nov 2009 10:09
Im glad u found 1.
as for rear shims i'm sure ive seen them too. possibly on Z1E, American Classics, or Klasmo?
most guys that add big tires have to go the other way. we have to mill the hub to bring the sprocket closer to the tire.
i do all I can to measure each side of the axle to a equal fixed point (swing arm pivot)to align the rear axle. then i put a straight edge on the front sprocket, and run it back to the rear sprocket.then the shimming , or milling begins.
but if u add a dif arm and swingarm, u must align the rear wheel with the front wheel, and then shim the rear rim , before u worry about the sprockets.that is a lot of fun. NOT.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- thompsonmx100
21 Nov 2009 10:19
Glad you found the right sprocket. that will make life easier. I thought someone would make one that would work.
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- mark1122
- Keep twisting it
21 Nov 2009 10:23
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
