Sprocket alignment?!? 630-530 conversion
- otakar
20 Nov 2009 18:30 - 21 Nov 2009 05:47
I read a lot on this web sight from many people about custom swing arms, oversized wheels, ETC.ETC. But I have never herd any of these same people talk about aligning the sprockets. After offsetting this, that, and the other, how do you make sure that the two sprockets are in the same plane. Please don't tell me that you do it by eye. I have been doing a lot of research on the web and have found many articles tellng me how important it is that the sprockets are in perfect alignment. How quickly chains and sprockets can be warn out if they are not aligned. How much HP can be lost if they are not aligned. For this reason I started looking at what tools are available, and have found a couple. Unfortunately all these tools help with is rear sprocket angle. this would all be fine when "one" is running a STOCK set up and the sprocket "surface plane" is all taken care of at the factory by the engineers. Here is my point; I am converting to a 530 chain from a 630 chain. when i bought the required parts, the front sprocket is offset by .25" from the stock while obviously the rear sprocket is also thinner than the stock 630 sprocket, offsetting the pair even more. So now, first of all putting the two sprocket planes into parallel is relatively simple, the tools for that adjustment exist, if the marks on the swing arm adjusters are not accurate enough. But, how do you check if they are in the same plane? Also, if they are not, and in my case the front sprocket is too far out, how do you space the rear sprocket farther out to put them in the same plane? Let's start an inteligent discussion about this. Since some of the stuff I have read states that as much as 10% of horse power can be lost in improper sprocket adjustment. If this is true than that 10% is going directly into wearing out the chain and sprockets. Now I have designed and will be building a laser tool to do the measurements, how do I space the rear sprocket out farther????
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Nov 2009 05:47 by otakar.
- kano
- Not Another Bloody Limey!
Re: Sprocket alignment?!?!?!?!
20 Nov 2009 18:38 - 20 Nov 2009 18:43
i used a long piece of metal to line mine up
flipped my rear sprocket as it had a off set already.
got me to a 5/8 offset front sprocket.
nice tool below for 80 bucks
laser sprocket alignment tool
Last edit: 20 Nov 2009 18:43 by kano.
- otakar
20 Nov 2009 19:00 - 20 Nov 2009 19:04
That is a very nice tool, but I refuse to pay $80 for it. The laser tool I am building will cost me a LOT less. I want to shoot from front to rear, since the front sprocket angle is a given and can not be changed. By putting the tool on the rear sprocket you can not tell if the two are in the same plane if the rear wheel is at a slight angle do to adjustment mark inaccuracies. But, mounting the rear sprocket backwards, since I have the room next to the tire is a good idea that will get me closer. But even that will still leave me about 3/16" out of plane with the front sprocket.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Nov 2009 19:04 by otakar.
- otakar
20 Nov 2009 19:06
What I would really like to know is how to space the rear sprocket farther out.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kano
20 Nov 2009 19:12
i have a spacer on my dymags that i took off ill measure its thickness tomorrow and get back to you if you want it its yours.
as for wheel twisting out of line,
i used a long flat piece of metal and i tried to make sure that the straight edge hit sprockets evenly,
i just went all through this with my bike as i put a gsx-r 02 complete rear end on my bike.
had to switch to 530 sprockets as well,
all becouse i wanted fatter wheels and tyres. :blink:
- otakar
20 Nov 2009 19:18 - 20 Nov 2009 19:19
The spacer I require would have to have the 80mm center hole. I am surprised that there is no company that makes something like .5mm shims that could be stacked to do this task.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Nov 2009 19:19 by otakar.
- kano
20 Nov 2009 19:25
it should work ill measure it tomorrow,
has a gpz1100 b1 rear sprocket holes already
- otakar
20 Nov 2009 19:25 - 20 Nov 2009 19:34
I just measured my offset "exactly and it is .2385" (6.06mm) if I use my rear sprocket properly. And, I just realized that I can not flip my rear sprocket backwards, because that will ADD .1145" (2.91mm) and not subtract it. If I install a 1/4" spacer under the rear sprocket I will be off only by .0115" (.3mm) that would be completely acceptable. Even 1mm at that distance would be fine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Nov 2009 19:34 by otakar.
- kano
20 Nov 2009 19:27
give it to me in mm bro, im English so i only work in metric lol.
- otakar
20 Nov 2009 19:36 - 20 Nov 2009 19:40
Post has been edited to contain both English and Metric systems. Since you English do not understand the English system any more. :lol: Here are a couple of pictures to show the sprocket I WILL be using on the left and the proper height sprocket on the right.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 20 Nov 2009 19:40 by otakar.
- kano
20 Nov 2009 19:39
I prefer metric they switched us limeys over in the 70's
i still work in feet and inches at work but always metric on my bike don't ask why lol.
- kano
20 Nov 2009 19:41
i think i have a 5mm spacer which i think will get you close enough,
anyway ill double check tomorrow and take a pic ok.
