tire help
  • hmeric7
  • hmeric7's Avatar Topic Author
tire help
29 Oct 2009 20:10
#330424
ye si hjave a 1977 kz1000 it has tube tires on it right now but need replaced. is there any way of putting regular tubeless tires on my factory rims and if so what sizes will fit. i have a 19 inch front and 16inch rear
mt90-16t on the rear right now
4.10 h19 on the front
1977 KZ 1000 LTD
  • PLUMMEN
  • PLUMMEN's Avatar
Re: tire help
29 Oct 2009 21:21
#330439
you needto run tubes with your stock rims B)
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: tire help
30 Oct 2009 03:58 - 30 Oct 2009 03:58
#330451
I second PLUMMEN...you are stuck with tubes if you have stock rims...unless you upgrade to newer generation suspension/wheels...and that will be much more expensive than a tube.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 30 Oct 2009 03:58 by Mcdroid.
  • otakar
  • otakar's Avatar
Re: tire help
30 Oct 2009 09:04
#330487
You can put an inertube in a tubeless tire. I do it on my 76 KZ900 all the time. When you install a new tube, make sure you install a new rubber rim strip also. Also use plenty of talcum powder during installation. Talc will insure the tube inflating straight and will prevent pinching.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • hmeric7
Re: tire help
30 Oct 2009 20:43
#330583
ok so i need a tube so do i have to put tube tires back on or can i put diff tires on and keep the tubes
1977 KZ 1000 LTD
  • PLUMMEN
  • PLUMMEN's Avatar
Re: tire help
30 Oct 2009 20:56
#330589
id look for tires marked tube/tubeless to be safe B)
  • otakar
  • otakar's Avatar
Re: tire help
31 Oct 2009 03:44
#330601
I have been using tubeless tires on tubed rims with tubes for years and never had a problem. I do not even use the rim locks, I just put a thin metal patch over the hole inside the rim.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Samwell
  • Samwell's Avatar
Re: tire help
31 Oct 2009 04:10
#330604
Most tires in our sizes will be marked, tube/tubeless. Even if they aren't, you're usually okay. Just be sure to replace your tubes with your tires as a set - the rubber inner tubes ages too and will likely crap out before the new tire is worn out.
  • timebomb33
  • timebomb33's Avatar
Re: tire help
31 Oct 2009 11:54
#330661
like otto said one of the first things i do when i change tires on a stock bike of my own is toss the rim locks kawi i think was a bit optimistic on how much power these actually make and you can use a tube in a tubeless tire.
I THINK MY POWERBAND BROKE
  • fredgarvin42
  • fredgarvin42's Avatar
Re: tire help
06 Nov 2009 13:16
#331800
All great scoop. Is there a protective band for stock mag wheels or something similar? Were about to go postal on this shop. My buddy just replaced his tires with Bridgestone Exedra tubeless tires on his 78 KZ 650 and it keeps going flat with a tube in it. Is the shop doing the work screwing the pooch? Are we missing something to suggest to do for a proper installation even though they should know how to put on a freakin tire?
Do ya REALLY need a toob? Mine (80 LTD 1000) didn't have tubes and they put them in mine when I replaced my tires. I'm the only one out of three cats that has not had a flat with my new tires.
The KZ 650 is going back to the shop again with a front flat after being repaired just yesterday (two tube flats in a week) and we're on the verge of pulling a Chris Farley in their shop. Just want it setup right. Thanks for lettin me vent! Please pelt me with your commentary.
Peace
1980 LTD 1000
1985 Ninja 600
1984 YZ 490
Austin,TX
  • otakar
  • otakar's Avatar
Re: tire help
06 Nov 2009 13:32 - 06 Nov 2009 13:42
#331804
First of all, Are talking spoked wheels or mag wheels? Second of all IF they are mag wheels, did they come with rim locks? A tubeless Mag rim is marked on the side as "Tubeless" OBVIOUSLY, you can NOT run a spoked rim without a tube, and that is all that's to that. There are two differences between a tubed solid wheel and a tubeless solid wheel. 1)tubeless rims do not have the two holes for the rim locks. 2)there is a small ridge on the inside base of the rim to prevent the tire from coming off the rim if it gos flat. You can run any solid wheel with a tubeless tire if; you seal the holes for the rim locks, but you may risk the tire coming off the rim if it ever gos flat while you are riding. You can conversely run a inner tube in any wheel, provided that the valve stem opening is properly sealed to the valve stem. If you DO run a tube, make sure that the inside of the rim is very clean so that any corrosion will not rub threw the tube.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 06 Nov 2009 13:42 by otakar.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: tire help
06 Nov 2009 17:07 - 06 Nov 2009 17:08
#331845
well that about covers that....try poking a hole in that explaination...:)
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 06 Nov 2009 17:08 by trianglelaguna.
