ZX12 swing arm on a 76 A4
  • flatblackA4
  • flatblackA4's Avatar Topic Author
12 Oct 2009 18:19 - 12 Oct 2009 18:19
#327146
Hey guys
Just wondering if the if a ZX12 swing arm will fit in my A4, is it worth the hassle or a total pain in the ass? I think a 180 tire would look way too cool on this bike. I'm a machinist by trade so I can mod a lot of thing if needed. Any insight would be greatly appreciated.
Last edit: 12 Oct 2009 18:19 by flatblackA4.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
Re: ZX12 swing arm on a 76 A4
12 Oct 2009 18:47
#327154
Not sure if they're a direct swap, but I'm sure that would look cool ;)
I you need to fab, oh well. I think it would be worth it.
Cheers!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • timebomb33
  • timebomb33's Avatar
12 Oct 2009 18:50
#327156
i've never measured them myself but i was told they are roughly about an inch bigger across than the stock swingarm pivot.
I THINK MY POWERBAND BROKE
  • Old Man Rock
  • Old Man Rock's Avatar
12 Oct 2009 19:08
#327166
"is it worth the hassle or a total pain in the ass"...
As one of our members just recently finished his ZX7 conversion that was wider where he had to split the frame, press it out wards slightly then put it all back together with reinforcement welds & gussets/plates and such.
Now with that in mind, still had to have some milling accomplished on his rear hub for chain alignments...
Then of course the upper and lower shock mounts.
Oh yeah, then you have to figure out all your electronic l0ocations & changes & modifications for the upper shock mount is now in the way...
Oh crap, the battery cage needs fabbing....
On & on the SAGA & PITA goes... :blush:
Now to answer your question....
PITA, yup you bet...
Frustrating at times, yup...
Oh Shit factor or I didn't think of that factor, yup....
Worth the hassle, yup, every damn bit of it... ;)
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • flatblackA4
12 Oct 2009 20:12
#327185
OK sounds like a total pita, if it is an inch wider at the pivot tube its not worth the hassle. I'd rather turn spacers than mill the pivot tube. It looks like I just may use an early gsxr 600 arm. I still want to keep the twin shocks as well. For some reason that look still appeals to me. Any other suggestions or $.02 are appreciated. Just want a bigger meat on the back.
Thanks for the replies guys.
  • Old Man Rock
13 Oct 2009 04:56
#327236
I went with the ZX6RR swing arm conversion...
Maybe will provide some insight...
kzrider.com/index.php?option=com_docman&...d&gid=430&Itemid=108
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
13 Oct 2009 11:20
#327322
all the gixxer arms seem to be easier/popular to swap,plus they look good with the dual shock mounts welded on(z1e sells the alum brackets to be welded on).i love the 190 on the back of my bike(the bike in my avatar).keep us posted,
leon holmes
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
13 Oct 2009 11:44 - 21 Oct 2009 12:11
#327337
I did a ZRX12 to mine. if u are a machinist , then this will be a cake walk.B)
here is a link to my project.i would try to use a 1/2" offset sprocket , rather than the 5/8" i used.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 21 Oct 2009 12:11 by mark1122.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
21 Oct 2009 12:13
#328767
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • flatblackA4
20 Nov 2009 13:30
#334876
been awhile moving forward too slow. got gsxr arm heres the mock up with a 200 tire looks really cool.
  • otakar
  • otakar's Avatar
20 Nov 2009 14:05
#334877
I'll stick to the trusty rusty. GS1100 swap. I'm too lazy to do all that cutting and welding.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
20 Nov 2009 14:39
#334882
I see u are off to a good start.B)
i cant wait to here if u have any difficulty aligning the rim, and sprockets.this is where the fun begins.
U will likely need as much offset as possible on the front sprocket, to help getting things aligned at the rear. i have a 5/8 offset on mine, and still had to mill the rear hub.
many get away with a 1/2". in your case, with the 200 tire (:woohoo: ), the more the marry er.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
