ZX12 swing arm on a 76 A4
- flatblackA4
Re: ZX12 swing arm on a 76 A4
22 Nov 2009 08:31
OK so heres a dumb question how do you keep the swingarm centered. Made spacers but it still has float side to side. Do I need to make bushings or will the chain and shocks locate the swingarm?
- otakar
22 Nov 2009 09:00
If that swing arm floats even a little bit, you will be munching on pavement. It will be like riding a bucking Bronco.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- thompsonmx100
22 Nov 2009 10:33
yeah what he said. You do not wnat any movement there. You need to make some spacers to center the swinger in the frame.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
1985 gpz750
Kz 650
- mark1122
- Keep twisting it
22 Nov 2009 15:01
flatblackA4 wrote:
Shim the arm so it is just a snug fit. then when u draw the arm bolt tight,it will pinch the frame and snug up against the arm.
some arms have side thrust bearings in them, some don't.tighten accordingly.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- flatblackA4
22 Nov 2009 16:23 - 22 Nov 2009 16:26
The gsxr arm doesn't have a thrust bearing, figure a bronze bushing should work. Thanks guys for all the insight.
Last edit: 22 Nov 2009 16:26 by flatblackA4.
