Pics of bar-end mirrors on KZ's
- toadson
11 Oct 2009 18:35
I've been looking at installing some bar-end mirrors on my LTD after I installed some Daytona touring bars a few weeks ago. The stock mirrors have always vibrated at highway speeds and now I have to tuck in my elbows to see behind me. I think the bar-end mirrors will look a lot better as well. The one thing I'm uncertain of is how I will mount them. I've seen some that mount on the very end of the bar, but my handle grips are not open on the ends. I thought they made some that mount elsewhere on your handlebars and extend over to the end of the bar too, but am not 100% sure.
If I wanted to mount mirrors on the end of my handlebars, would I have to buy some open ended grips and just move the grips towards the center of the bars? It's probably a stupid question, but I would like to see some pics anyone may have of these style mirrors on their KZ. Thanks!
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread:
kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
- roy-b-boy-b
- chance
- Life long biker/
Re: Pics of bar-end mirrors on KZ's
11 Oct 2009 19:18
Take a razor blade and cut off the ends of your grips..
- TeK9iNe
- What did you do!?!
11 Oct 2009 19:37
The bar end mirrors are fine for passing safeties. But they don't really work all that great for seeing angles behind you.
OEM mirror positions are where they are quite simply because thats the best/safest place for them. Deviating from those positions means an ever decreasing area of rear view coverage. :blink: blah...
Just something to think about...
I like the chopper style mirrors that emgo has personally. They retain the origional viewing angles pretty well, but are slimmer and newer, and cooler
Cheers, n' good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- ArthurGoVroom
- I'd rather ride it than shine it
11 Oct 2009 20:13
That wasn't a stupid question at all, I wondered the same thing about the closed-end grips.
Roy-b, did you make those aluminum (?) header flanges or does somebody sell them?
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
- donthekawguy
11 Oct 2009 23:19 - 11 Oct 2009 23:20
I always put bar end mirrors on all my bikes. If you do make sure you get the ones with the rubber plug that expands. The metal ones will fall out. As for not being able to see, with the stock ones all you can see is your elbows. The bar ends give you a lot better field of vision IMO.
Only one shows in the pic but you get the idea. I also use Grab On foam grips.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
Last edit: 11 Oct 2009 23:20 by donthekawguy.
- chance
- Life long biker/
12 Oct 2009 02:47 - 12 Oct 2009 02:56
ArthurGoVroom wrote:
Heres 2 choices Z1 is the cheapest they both have em to fit other models too..
Bike bandit part #563798-001 $19.32 HOLDER-EXHAUST PIPEThat wasn't a stupid question at all, I wondered the same thing about the closed-end grips.
Last edit: 12 Oct 2009 02:56 by chance. Reason: add info
- chance
- Life long biker/
12 Oct 2009 02:53
Exhaust Flanges KZ1000 KZ1100 ZN1100
18069-1015
OEM: 18069-1015 --
Aluminum Exhaust Flanges sold individually 4 needed for set. Originally fitted on the 81 and up Kawasaki KZ1000's, these also fit early Kawasaki KZ1000 77-80. Genuine Kawasaki Motorcycle part
$13.75
18069-1015
OEM: 18069-1015 --
$13.75
- HerrDeacon
12 Oct 2009 03:24
Here's a couple of pics of mine. I really like them. I don't get much vibration. None at all on the clutch side, but get a bit on the throttle side. As far as viewing area, I find them good. Although, with them on clubmans you have to actually tilt your head down to look at them. Wouldn't be a problem though with normal bars.
- roy-b-boy-b
12 Oct 2009 04:20
I can see good out of my mirrors. The don't buzz like the plastic stock mirrors.
Those aluminum flanges are a stock piece. Roy
- saltydog
12 Oct 2009 06:02
I had trouble finding good mirrors for my KZ1000 when I broke one of the originals. My criteria for what I wanted was nice looking, no vibration, and cheap. I found them on Ebay for $15.00. They came from a late model Suzuki M50. I've been real pleased. I bought a set of Emgo's that were supposed to be original style but they vibrate so bad as to be unusable.
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
- Jeff.Saunders
12 Oct 2009 10:41
I have mine UNDER the bars. It may sound strange, but you look under your arm and have an unobscured view backwards.
