Triple tree custom work
- ramtough_63
Re: Triple tree custom work
09 Dec 2014 18:55Attachment 100_6635.jpg not found
Bolt on gull-wing design complete with gauge mounts & steering stops
Plug-n-Play Les Holt
Attachment WP_20140519_017.jpg not found
19" wheel conversion
Attachment WP_20140330_001.jpg not found
1/2" 520 offset counter sprocket
Plug-n-Play Leon 531blackbanshi
Attachment WP_20140518_057.jpg not found
03 zx6 rear swing-arm
narrowed with bushings
Plug-N-Play Leon
Attachment green_2014-12-10.jpg not found
I have 100's of pics of their work
pure art!
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
The following user(s) said Thank You: Bad Kaw, 531blackbanshee
- PetesPonies
02 Aug 2015 18:44
I love the work shown here. Its been several years . anyone producing any of these parts now?
- kaw-a-holic
02 Aug 2015 22:09
I would PM 531blackbanshee (leon) or Les Holt. Last I talked to Les was a couple of months ago, he was still moving shops not sure if he can help yet.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- Gordy
03 Aug 2015 03:40
Cognito moto do this kind of thing.
Maybe useful for those wanting something made
cognitomoto.com/products/copy-of-copy-of...rame-conversion-stem
I've not used them as they are in the US.
- BlackEyeCafe
29 Nov 2016 19:15 - 29 Nov 2016 19:15
Great work 531blackbanshee
I apologize for bringing up an old post but it's a great read.
I have a question about how you locate the spot for the snap ring and how you go about installing it. If you have pictures that would be awesome.
Game changing work brother, glad you put it up for all to see
Thanks
Thanks
1977 KZ650 C
Jets - Main 115 - Pilot 17.5 - Needles - Position 3 - NGK BR7ES
Last edit: 29 Nov 2016 19:15 by BlackEyeCafe.
30 Nov 2016 06:47
everyone is a little different.but there all kinda the same if that makes any sense :whistle:
most of the ones that use the snap ring is zx9's and i never take them apart.(but the stem pushes out the bottom and the snap ring registers on a counter bore thats machined into the lower triple.)
on the zx9 to kz conversion i cut the stem off with a port-a-band saw and then mill them flat.
leaving the zx stem in the lower triple to be used as the bushing,
then machine the id (sometimes it just needs honed)of the zx stem to be a press fit for the kz stem and tig weld it.
otherwise i press the stem out of the donor lower triple and machine the lower triple out with a counterbore,
then machine out a steel bushing to be a press fit match to it and press it onto the stem and tig it.
then press the whole lot into the donor lower triple.
then i address the donor upper by either machining the hole larger or machining and installing a bushing to reduce the hole to match the kz stem.
on 81 and later kz's that have the snap ring stem that presses out of the lower aluminum triple if i can i just machine the donor stem as the bushing and machine a counterbore to register the snap ring on and then cut the donor stem off mill it flat and press the kz stem in (from the bottom naturally)
here is boostables zx10 to 81 or later kz.
hth,
hth,
- 750 R1
- BlackEyeCafe
30 Nov 2016 14:11 - 30 Nov 2016 15:18
Thanks brother, that cleared it all up. Hopefully I can post a build thread in a couple months.
Ride safe
Ride safe
1977 KZ650 C
Last edit: 30 Nov 2016 15:18 by BlackEyeCafe.
01 Dec 2016 05:45
happy to help
definitely post up some pics of your build :evil:
thanks for the kind words.
- gtask8
03 May 2024 20:04 - 03 May 2024 20:04
Not sure if you’re still in the game for KZ swaps but I have an ZX6 Front end I’d like to slip onto my KZ440. Are you available for doing the work, or if not maybe you could give me some advice or more detailed tips? I have access to a Lathe & Mill.
Last edit: 03 May 2024 20:04 by gtask8.
04 May 2024 07:10
If not, check with PDM. There is a link at the bottom of this page.
04 May 2024 16:08 - 04 May 2024 16:09
Just some how to do........
Last edit: 04 May 2024 16:09 by Scirocco.
