Wheel Alignment Issues
- chance
- Life long biker/
Re: Wheel Alignment Issues
14 Sep 2009 16:48
Yep thats the wrong caliper 80s for sure. The rotor looks right soooo
- chance
- Life long biker/
- beefsquasher
19 Sep 2009 13:35
Figured it out!
I bought an LTD wheel on ebay, complete with cush drive and disc.
Turns out, I hand LTD wheel, but the brake rotor and cush drive were from a spoke wheel model.
The LTD cush drive is taller, and the disc is flatter, thus moving the wheel to the right, which would put it in the middle of my swingarm.
-Dave
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- PLUMMEN
19 Sep 2009 13:57
chance wrote:
78 kz1000 used that style caliperThat from what I can see doesn't look like a 77/78 caliper it looks 80s so the wrong year rear may be the incorrect one. I will look at the 77 and take some pics if the rear rim& caliper. A wrong caliper and disc will throw it off I'll get back to you tommorrow unless someome else can shed some light on this.
- chance
- Life long biker/
- chance
- Life long biker/
19 Sep 2009 16:43
Glad you found out what was wrong. Do you still have your old wheel ? Roy Bs looking for one if you want to get off of it.
- chance
- Life long biker/
19 Sep 2009 17:10
PLUMMEN wrote:
Correct thats a 78 spoke wheel rotor..Not used on the ltd 16in mag..chance wrote:78 kz1000 used that style caliperThat from what I can see doesn't look like a 77/78 caliper it looks 80s so the wrong year rear may be the incorrect one. I will look at the 77 and take some pics if the rear rim& caliper. A wrong caliper and disc will throw it off I'll get back to you tommorrow unless someome else can shed some light on this.
- PLUMMEN
19 Sep 2009 17:59
beefsquasher wrote:
do you have a side shot of the bike?My bike seems to have a wheel alignment issue. The brake caliper and brake stay line up. So do the sprockets and chain. The swingarm is stock and has new bearings/spindle.
The problem is that the whole wheel is offset to the left about 3/4". The chain actually lightly rubs on the left sidewall of the tire, and there is tons of space on the right where the caliper is. I can't move the caliper or sprocket around b/c they wouldn;t line up with the stay or the engine sprocket anymore.
I bought the bike like this. Is it possible that I have some mismatched parts somewhere?
Everything is tight and straight, and the bike goes straight, handles normally, stops and goes properly.
What is going on? Maybe some pictures are in order...
The tire is stock size for the cast wheels (MT90/130/90 - 16).
-Dave
- chance
- Life long biker/
- PLUMMEN
20 Sep 2009 08:52
chance wrote:
those are both 78 kz A series bikes,top one just has mag wheels installed
- chance
- Life long biker/
- PLUMMEN
20 Sep 2009 17:02
blue bike in your avatar is a B series,the purple bike and red bike you posted are both A series bikes
