brake testing?
- mzandmz
Re: brake testing?
15 Aug 2009 18:30
Yes that what I was talking about but making my own.
New to Family, 1979 KZ440 LTD
Re: brake testing?
15 Aug 2009 18:34
I use a pressure bleeder tank (KD 2222) with a special adapter I made. This works really well as it pushes fluid through the entire brake system with both front bleeders open at the same time (no air bubble can get trapped). If you know a professional car mechanic you may be able to gain access to a pressure bleeder. You'll just need to make your own adapter as I've never seen one for bikes. Ed
- mzandmz
Re: brake testing?
15 Aug 2009 19:33
Thats like I was thinking about.Just dont have an extra cap laying around....
Re: brake testing?
15 Aug 2009 19:49
If you get around to doing it this way you must seal the inside of the custom cap adapter with epoxy. (Notice how the inside of mine looks a little dark?) You must do this because the cap is vented. If you don't, when you apply pressure it will leak. (Ask me how I know.
) Ed
- Bluemeanie
Re: brake testing?
16 Aug 2009 06:00 - 16 Aug 2009 06:00
I flushed mine out a couple months ago using my Mighty Vac. These things are better than sliced bread! It "pulls" the fluid through the system and being under vacuum it also pulls out any air.
Last edit: 16 Aug 2009 06:00 by Bluemeanie.
- Bicycle Lee
Re: brake testing?
16 Aug 2009 15:52
thanks guys... it all boiled down to me being more patient, something I often struggle with.... haha
1978 KZ1000 police
