brake testing?
- Bicycle Lee
brake testing?
15 Aug 2009 10:59
So I'm finally putting the bike back together and I just tried to test the front brakes... I bled the lines and still am getting little to no resistance when I squeeze the lever. Do you need to have the cap to the master cylinder on when bleeding the brakes? I don't know why that would make a difference, but I'm just puzzled because when I disassembled the bike the brakes worked fine. I also just want to exhaust all of the options before I invest in rebuild kits.
What is the proper way to reassemble the brake system?
1978 KZ1000 police
- PLUMMEN
Re: brake testing?
15 Aug 2009 11:00
keep on bleeding them,it just takes a while sometimes
- violentvintagecycles
Re: brake testing?
15 Aug 2009 12:28
Alot of times it takes alot longer than we would think to bleed. It might be good to pump em then secure the brake lever so its squeezed then crack the bleed nipple just a little and let the air dribble out. Youll see little air bubbles leaking out and youll eventually get good pressure.
- kano
- Not Another Bloody Limey!
Re: brake testing?
15 Aug 2009 12:40
PLUMMEN wrote:
you can say that again bro!
my hydrolic clutch took ages too lol.
- mzandmz
Re: brake testing?
15 Aug 2009 13:01 - 15 Aug 2009 13:03
Yes mine took about 5 min. to finaly pump up. I change the boot on the brake line near the master cylinder.It was ugly and split in half. Anyway Sence it doesn't have as much volume/travel like a car/truck its hard to pump and hold.Theres alot of pumping but no hold until you get through a few minutes of doing it.Plus I wanted to flush out the OLD brake fliud and get fresh new fluid in there.
New to Family, 1979 KZ440 LTD
Last edit: 15 Aug 2009 13:03 by mzandmz.
- bountyhunter
Re: brake testing?
15 Aug 2009 14:30
Bicycle Lee wrote:
You better have something over it to keep the fluid from squirting onto the gas tank....Do you need to have the cap to the master cylinder on when bleeding the brakes?
- donthekawguy
Re: brake testing?
15 Aug 2009 14:33
On my 78 it took almost a week. On my 77 I got smart and used a bleeder kit. No problem.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Bicycle Lee
Re: brake testing?
15 Aug 2009 15:44
I know I need a cap, but I was wondering if that was an integral part of getting the pressure up. I bled them until I didn't see bubbles and the fluid started coming out "clear" meaning the new fluid made it all the way through....
1978 KZ1000 police
- mzandmz
Re: brake testing?
15 Aug 2009 16:05
No the pressure is made through the piston off the lever pushing in and forcing fluid down the hose. Cap just helps seal in brake fluid and seal out moisture thats drawn by brake fluid.
- mzandmz
Re: brake testing?
15 Aug 2009 16:08
I thought of finding a cap that would fit tight that could have a hose attached and aply pressure to it slowly forcing down the fluid. Probably a clear one so you can keep an eye on the level. Safety first. Cover tank,cover eyes with protection.
- bountyhunter
Re: brake testing?
15 Aug 2009 16:53 - 15 Aug 2009 16:54
Bicycle Lee wrote:
If you have a mechanical pressure switch for the brake light along the line going down to the caliper, you may have to crack the fitting to allow air to push out if there is air trapped at the switch.
Nope. When I bleed the front, I leave the cap off and fold up a clean shop rag and lay it over the reservoir. I open the lower drain fitting and put a clear tube on it to dump into a jar. Add fluid at the top and pump slowly. Keep adding before the fluid gets low or it will gulp air and screw up the bleed. Eventually, you should be able to get the air out.I know I need a cap, but I was wondering if that was an integral part of getting the pressure up.
Last edit: 15 Aug 2009 16:54 by bountyhunter.
- bountyhunter
Re: brake testing?
15 Aug 2009 16:56
mzandmz wrote:
I think they make something like that called "powerbleed" or some similar name. I have seen them used on cars.I thought of finding a cap that would fit tight that could have a hose attached and aply pressure to it slowly forcing down the fluid. Probably a clear one so you can keep an eye on the level. Safety first. Cover tank,cover eyes with protection.
