Master Cylinder change
- Darkangel
27 Jun 2009 20:28 - 27 Jun 2009 20:34
Do you think this would work on my bike guys...give your opinion on how you think it looks?
After market master cyl
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
Last edit: 27 Jun 2009 20:34 by Darkangel.
Re: Master Cylinder change
27 Jun 2009 20:38
What's wrong with the existing m/c?
Good Luck!
Good Luck!
- Darkangel
27 Jun 2009 20:46
it is too large for the clip on and it make me have to move the throttle control over, and it rubs against my bar ends
- Yojymbo!
27 Jun 2009 23:40
I'm going to use a GSXR master cylinder and remote resevoir for my single front disk brake on my 650. Not sure if it will be as bad ass as I hope so I'm keeping the original as well. I don't see why it would be a problem other than maybe making the front brakes a little more touchy.
- Darkangel
28 Jun 2009 14:11
I would like to have one of those all in one systems...Like I hit the front brakes and it operated both...that would be cool!
- Yojymbo!
- Yojymbo!
28 Jun 2009 14:17
Okay, that was a bit blunt. But seriously there is a reason they are seperate.
- Darkangel
28 Jun 2009 14:26
yeah...and i am probably not thinking about it right now...but yeah I know. But when you guys say touchy what do you mean?
- Old Man Rock
28 Jun 2009 15:17
Touchy equates to throwing your ass over the handle bars.... :blink:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Yojymbo!
28 Jun 2009 18:04
Exactly. The front brake might to most of the braking in one respect but I use my rear break much more often. Nobody hits the front break to slow down a few MPH.
- Lt.Dan
28 Jun 2009 20:04
Yojymbo! wrote:
Do you know that most Goldwings have an integrated system where the rear brake controls the rear disk and the left front disk and the front brake lever controls the right front rotor.
- Yojymbo!
