Picking up a complete 1994zx600 front end CHEAP.
- kzmarvo
15 Jun 2009 17:00
Gonna swap the whole front of my bike to a zx600, it is off a 1994. What all is involved? I am getting the master cylinder for the zx as well.
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- Mark Wing
Re: Picking up a complete 1994zx600 front end CHEAP.
15 Jun 2009 17:54
Hard to say. What kind of bike are you planning to put the front end on.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- kzmarvo
15 Jun 2009 18:03 - 15 Jun 2009 18:03
74 900
Last edit: 15 Jun 2009 18:03 by kzmarvo.
- Bdog
- Sweep the leg johnny!!!
15 Jun 2009 18:58
I believe the 94 should swap over directly, bearing and all. I had a early 90s 600c model and it would slide right in. I also had a 95-97 600r that was a little different and needed to have the stems swapped in the lower triple to work. Have fun shouldn't be too difficult.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- kzmarvo
15 Jun 2009 19:04
man thats great,thanks....:woohoo:
- Old Man Rock
15 Jun 2009 19:37
Everything you need for this front end on a 1976kz900-Aw which is basically identical to yours...
kzrider.com/index.php?option=com_docman&...d&gid=431&Itemid=108
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzmarvo
15 Jun 2009 21:30
Thanks,looks to be pretty straight forward,the front end is from a 1994zx6r.
