Fork Tube Bolt
  • shannonbeau
  • shannonbeau's Avatar Topic Author
  • It's my first bike. 82 KZ 1100a
Fork Tube Bolt
09 Jun 2009 14:44
#297754
Anyone know what the actual size of the Lower Fork Bolt on a 82 KZ 1100 is? I stripped out the allen head on mine and would like to get one quickly instead of waiting 10 days for an OEM to come in.
OEM number 44041-040..
I think it s a M8x1 but I am not sure.
Just got an 82 KZ 1100, working to fix it up as my first bike.
Re: Fork Tube Bolt
09 Jun 2009 15:14
#297759
Why not just remove the same bolt from the other side and take it to the hardware store for matching.
Good Luck! :)
Re: Fork Tube Bolt
09 Jun 2009 15:40
#297762
I don't understand. You stripped the Allen head, but did you ever get the bolt out? If so, why not use it for matching? If not, how will you get it out? Ed
  • shannonbeau
Re: Fork Tube Bolt
09 Jun 2009 21:44
#297936
I got the bolt out. I'll ask the hardware store.
Should I ask them about the rest of my KZ Questions?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Fork Tube Bolt
09 Jun 2009 21:49
#297941
ouch! :laugh:
  • shannonbeau
Re: Fork Tube Bolt
10 Jun 2009 13:29 - 10 Jun 2009 13:30
#298052
Yeah, OUCH... Yesterday was a really bad day. Just didn't expect the response. Would rather get a response if someone knew what the size was rather than something that sounds like what my boss would say to me.
The dealerships won't tell me the size of the bolt and they will take about 8 days to get the bolt in. I am in eastern Iowa. Not too many OEM places on hand. The bike was supposed to be done for a poker run for a charity this weekend and it looks like it won't now.
I was just asking what the size of bolt it was so that I could check that hardware store for the bolt.
I cannot find the specs on the bolt anywhere online and I have spend a ton of time looking for it. If anyone knows the answer or where I can find it. Please let me know.
P.S. Didn't mean to offend anyone. Sorry if I did.
Last edit: 10 Jun 2009 13:30 by shannonbeau.
  • OnkelB
  • OnkelB's Avatar
Re: Fork Tube Bolt
10 Jun 2009 14:25 - 10 Jun 2009 14:37
#298066
Can't help you with the length but if it´s an 8 mm bolt I'm pretty sure it's 1.25 pitch (regular/coarse metric pitch, 8x1.25).
8x1 would be fine metric pitch, as far as I know the only nuts/bolts on a KZ that are fine pitch are the lower triple tree clamp bolts, caliper mounting bolts and upper rear shock mount nuts (plus maybe the steering stem top bolt).
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 10 Jun 2009 14:37 by OnkelB. Reason: Typo fix...
Re: Fork Tube Bolt
10 Jun 2009 16:11
#298090
If it was my response that stepped on a nerve I apoligize. However, I wasn't being a wise guy. When I replaced the bolts in my KZ650 forks the new Genuine Kaw bolts (correct part number) from the dealer were about 1/4" shorter than the ones I removed (I destroyed the first one in the removal process). The new ones worked, but after my experience I thought checking using the original as the model made sense. Maybe I should have explained this in my response. Ed
  • timebomb33
  • timebomb33's Avatar
Re: Fork Tube Bolt
10 Jun 2009 18:34 - 10 Jun 2009 18:38
#298160
i haven't looked at a set of kawi forks for awhile but i have a set of the bike right now if you want i'll go and remove one bolt and see if i can get the size and pitch for you.your buddy the wrench i can't remember his name sorry ask him if he has any sporster forks kicking around i think they are the same bolt if i remember right h-d forks are showa from japan so it should be the same. but e-mail me back right away if you want me to check for you. by the way i 'm doing a little remembering now and i think your right 8x1mm i think is right
I THINK MY POWERBAND BROKE
Last edit: 10 Jun 2009 18:38 by timebomb33.
  • TexasKZ
  • TexasKZ's Avatar
Re: Fork Tube Bolt
10 Jun 2009 19:42
#298182
8 x 1.25
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Fork Tube Bolt
10 Jun 2009 19:48
#298183
fastenal or nebraska/iowa fasteners should have something like that i would think B)
  • shannonbeau
Re: Fork Tube Bolt
12 Jun 2009 12:25
#298624
That is a huge help, thank you so much.
