1989 ZX7R tripple tree
  • Captaingamez
  • Captaingamez's Avatar Topic Author
06 Jun 2009 22:42
#296886
What needs to be done to put a 1989 ZX7R tripple tree on a 1979 KZ1000?
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
  • Captaingamez
Re: 1989 ZX7R tripple tree
09 Jun 2009 13:58
#297745
so im guessing noone has any input or has tried this?
1971 Yamaha AT1
1971 Skiroule 300rr
  • kano
  • kano's Avatar
  • Not Another Bloody Limey!
09 Jun 2009 14:29
#297748
i'd say ppl are tired of answering the same question every 2 weeks lol.
from what ive read it should bolt up np with a washer on top,
i might be wrong though do you have the zx7 trees yet?
if so take a measurement and ill compare it to my kz1000 spares,
  • Mark Wing
  • Mark Wing's Avatar
09 Jun 2009 16:49
#297774
To put an 92 ZX7 fork on my bike I had to switch stems.
Mark
Yorba Linda Cal.
  • timebomb33
  • timebomb33's Avatar
09 Jun 2009 17:43
#297805
what did you guy's do for steering stops
I THINK MY POWERBAND BROKE
  • tw..
  • tw..'s Avatar
10 Jun 2009 06:56
#297993
I did it but it was a while ago and I didn't write too much down. The biggest thing is having the correct tappered stem bearings. I think I used stem bearings from a suzuki. I believe I ordered from Allballs. I know AllBalls can help you find the correct bearings.
Steering stop is an issue. Other than that It's a direct bolt on, no need to switch stems on the 89 model trees.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • galaxian
  • galaxian's Avatar
10 Jun 2009 07:27
#297996
I put the 96 zx7r forks on my kz1000 just swapped stems. As far as steering stops the bottom zx7 triple had nubs that work ok but need some attention to get right.
1977 KZ1000A1, 1979 KZ650 C3
  • elseed
  • elseed's Avatar
10 Jun 2009 09:15
#298005
I have these '89 forks on my Z1. No machining involved for that - I only had to get a couple bearing shims -- the stem was thinner than stock, so added like a 1mm/2mm bearing (just a ring with ID of shaft, OD of stock stem) at top bottom. Sorry, don't have details handy. Length was already good, just a tad longer -- used the ZX7 nut but Z1 grease cap.
Steering stops were close, allowed a little bit of bump to gas tank. I put pieces of plastic tubing over them to prevent hard bump. Turning radius is greatly reduced, by the way. Parking lots involve a lot of back/forth, but no problem on the road.
'75 Z1B with mods
  • Captaingamez
10 Jun 2009 10:05 - 10 Jun 2009 10:06
#298013
As in the 1989 model, we are talking about the one with 43mm conventional style front forks.
what kind of bearings did you get?
where can i get Bearing shims?
1971 Yamaha AT1
1971 Skiroule 300rr
Last edit: 10 Jun 2009 10:06 by Captaingamez. Reason: spelling.
  • Captaingamez
10 Jun 2009 10:21
#298017
Also, are the stems the same between your 1975 z and my 1979?
1971 Yamaha AT1
1971 Skiroule 300rr
  • elseed
  • elseed's Avatar
10 Jun 2009 17:00
#298100
Yes, conventional 43mm forks (non-upside down???).
I got new tapered bearings, typical aftermarket replacement for the old ball bearings. Like from Z1E. I knocked the old ones out with the largest smashing devices I could lay hands on.
Bearing spacers/shims you can get from bearing supply houses - I used yellow pages in my town. Call machine shops or the like to find a source. Metric, stainless steel, with OD, ID, and depth dimensions. Like these: www.qbcbearings.com/BuyRFQ/ThrustB_Spacer_OR_SS_M.htm
But is '75 Z1 same as '79 KZ? Probably not! My experience doing mods of this sort is few can really help you unless parts are in hand, dimensions published, etc. I think the KZ steering head got beefier around '76, but honestly don't know.
Could try some measures if you want, but might take a few days to get garage time.
'75 Z1B with mods
  • Old Man Rock
  • Old Man Rock's Avatar
10 Jun 2009 18:02
#298145
Ok, this was for my ZX636 conversion but the principles are the same...
My frame steering stop was broken so some fab was required and now I use the zx fork stops just fine...
members.cox.net/ruinsofstei/Old%20Man%20...End%20Conversion.pdf
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
