1989 ZX7R tripple tree
  • Captaingamez
  • Captaingamez's Avatar Topic Author
Re: 1989 ZX7R tripple tree
10 Jun 2009 19:25
#298180
I made some measurements today and ralized that the stem is long enough. but it is thinner than the stock stem. so it takes smaller I.D. bearings. What are the chances of gettin some pics of your setup Elseeed?
1979 Kz1000 MKII road racer project
1994 Seca II, pile in the corner
1973 Honda cb175 cafe racer
1971 Yamaha AT1
1975 Massey Fergusson MF440
1971 Skiroule 300rr
  • PLUMMEN
  • PLUMMEN's Avatar
10 Jun 2009 20:31
#298200
Captaingamez wrote:
Also, are the stems the same between your 1975 z and my 1979?
im guessing theyre pretty close other than the slot in the 79 stem for steering head lock B)
  • Captaingamez
11 Jun 2009 09:52
#298353
Yes they are the same. i did the measuring this morning as well. now i need to find some Lathe access to make a shim for the bearings.
1971 Yamaha AT1
1971 Skiroule 300rr
  • elseed
  • elseed's Avatar
11 Jun 2009 10:11 - 11 Jun 2009 10:40
#298360
Okey dokey - will get fresh pics.
Anyways, how far are you going? This part of the racer project listed in your sig? When I started nudging things around on my bike there was a cascade effect on systems and assemblies. You going to use the ZX wheel?
I committed to the full ZX front including wheels, brakes, master cylinder on bar. Wheel diameter is smaller, changes frame geometry -- everything clears, but had to watch Kerker clearance at pavement, oil cooler to wheel. Steering radius is much tighter but fine on the road. The fork tube just bumps my tank at full stop, has scratched paint. I also committed to modern rear suspension and swingarm with ZX11 donor parts -- I'm using ZX11 wheels front/back.
I think the clip-ons were banging the tank or squashing fingers, also uncomfortable for me. So I have an aftermarket superbike bar kit. ZX7 triple meant new mounting concepts for instruments, headlight, and turn signals.
'75 Z1B with mods
Last edit: 11 Jun 2009 10:40 by elseed.
  • Captaingamez
11 Jun 2009 20:13
#298519
Well, im going pretty far with it. im going to use a zx6 front wheel or a zx 11. the zx6 front is alot lighter than the zx11. im using a zx9 rear wheel on a gs1100 aluminum swingarm. but the frame is totally stripped right now being prepped for bracing, which will hopefully be getting done this weekend.
Im keeping the engine mostly stock for now. just minor upgrades until i can afford a full rebuild. like manual cam chain tensioner, a light port and polish job, all new seals and gaskets, ect.
My priority is chassis performance first.
And i think i figured out that the stock 89' zx6 steering stem bearings will fit a kz1000. the top bearing is 1mm less in O.D. the bottom is the same. the widths are slightly differant but not by more than 1mm. so i ordered them from z1 enterprises.
1971 Yamaha AT1
1971 Skiroule 300rr
  • tw..
  • tw..'s Avatar
12 Jun 2009 06:21
#298561
Elseed, who made your head light ear brackets? I don't want to hi-jack this thread but just had to ask this question.
2-1976 KZ900 A4
1995 KZ1000 Police bike
1978 Z1R
  • elseed
  • elseed's Avatar
12 Jun 2009 09:55
#298601
Made by GSG Moko - German company. Got them from a guy who distributes Euro moto stuff out of Phoenix. click here
'75 Z1B with mods
  • elseed
  • elseed's Avatar
12 Jun 2009 10:13 - 12 Jun 2009 10:17
#298603
Captaingamez wrote:
Well, im going pretty far with it. ... And i think i figured out that the stock 89' zx6 steering stem bearings will fit a kz1000. the top bearing is 1mm less in O.D. the bottom is the same. the widths are slightly differant but not by more than 1mm. so i ordered them from z1 enterprises.
Sounds like a project!
So you're going to fit ZX6 bearings into the KZ frame? I don't quite understand how you'll press the bearing into the frame - bearing spacers (like 0.5mm) to the OD? I did the opposite - got KZ bearings that fit the frame, used spacers to neck down the ID to fit the thinner ZX stem. KZ stem 30mm top/bottom I think. Frame like 52mm top/48mm bottom (or vice versa). I got some 30mm OD spacers necking down to stem diameter -- e.g. 1mm thick = 28mm or such. For the ZX7 the stem diameters change at top/bottom.
I uploaded some pictures, though I'm not sure they'll help you as I don't wanna disassemble. Poke around and let me know if you're interested in something specific. some pics here (some big)
You can see steering stop here and some details. I notice I have a zip tie on top of bearing dust cup/cover. I remember having trouble getting stock Z1 part to work there.
I'm familiar with that part of the project! :)
'75 Z1B with mods
Last edit: 12 Jun 2009 10:17 by elseed.
