I blew up a wheel bearing!!
- hardr0ck68
- Who put the what in the where?
15 May 2009 19:13
I was having serious rear wheel issues, the rear wheel was moving all around the adjustment range and making alot of clunking noises....
I decided it was unride-able and pulled it all apart. The hub bearing was in a thousand pieces! I am missing the piece that spaces the hub bearing and the left wheel bearing. When looking through my spare wheel parts I also found a rear wheel spacer (brake side) that was longer than the spacer I had on the bike... but I am not sure which one to really use.
I will post some pictures and parts diagrams, but yeah it was a bad day for me, luckily it all happened very close to home, and there was no serious injuries!
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- l0g1c
- Hanging on for dear life.
Re: I blew up a wheel bearing!!
15 May 2009 19:30
Oh, I've been there, man. My bearing had disintegrated as well, so I was left to pound the outer races out with a drift punch and a hammer. By the time I was done, I had obliterated the punch.
Glad to hear you weren't hurt! I know my heart skipped a beat when I saw what I was riding on.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
'72 CB350K
Omaha, NE
- toadson
15 May 2009 19:32
Glad to hear you didn't get hurt, that could have been a bad accident. I replaced my rear bearing when I installed my new swing arm and chain as a preventative measure. I've got the front one too, but haven't got around to it yet. Kind of weird you lost the spacer for the wheel, I don't see how that could have happened, but who knows. Get us some pics and I'm sure someone can help ya out!
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread:
kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
- hardr0ck68
15 May 2009 19:50
I am missing parts 12 and 18 from the rear end.
It is not really that off for parts to be missing, my bike was about hopeless when I got it... it has been taken apart by many people with more good intentions than brains many times (this includes my initial attempts at "repairs").
I just want to find the parts quickly and get this sorted, because the bike is running better every day (with work every evening)
1977 kz650 c1
- hardr0ck68
15 May 2009 19:51
oops that is not the parts diagram that is a photo of a passed out korean man in the elevator...he pissed himself.
lets try this again!
1977 kz650 c1
- hardr0ck68
15 May 2009 20:08
Also here is a picture of the spacer I have on the bike (on the right, the short one) and one that I have in my box of wheel parts (the one on the left)
They are both for 650's as far as I know, and I honestly do not know witch one to use on my bike... I am hoping someone knows.
1977 kz650 c1
- roy-b-boy-b
16 May 2009 04:46
Just install each spacer and see which one brings the rear sprocket in line with the front sprocket. Roy
- Dragone
16 May 2009 05:07 - 16 May 2009 05:08oops that is not the parts diagram that is a photo of a passed out korean man in the elevator...he pissed himself.
and stay away from elevators....
Last edit: 16 May 2009 05:08 by Dragone.
- hardr0ck68
16 May 2009 08:18
I need to find part 42036-1005 Sleeve, Rear hub coupler
does anyone have one? It is off of a 77 kz650 c1.
Can someone run it through cross reference software?
I really need to find one so I can get back on the road!
P.s.
It was common to see things like that in Korea... lots of discussions happen over bottle after bottle of liquor. We were on the 13th floor of a building so we road down with him, we just stood out side of his puddle.
P.s.
1977 kz650 c1
- gane
16 May 2009 17:44
Hardrock. If memory serves, the spacer you're missing (#12) in diagram, fits inside the cush drive's bearing, and mates to the l/h wheel hub bearing. If I'm correct (and I believe I am ), neither of shown spacers are the one you need. put your' axle in cush drive and look to it's bearing. if I am correct, the missing spacer's duty will be obvious, it not only centers drive, but in stages locates all 3 bearings. luck g
[img][/img] 1977 KZ1000A1
- hardr0ck68
16 May 2009 20:31
You are right gare, the pictured spacers are both #14
One came from the bike and another from a parts box... the problem is, I don't know which one is correct. The one I removed from the bike could be wrong, because it came out of the parts box last year.
So to sum my problems up...
I am missing part number 12
I do not know what models used this part to help find a replacement
I have two brake side spacers (part number 14) and don't know which one is correct.
I may or may not need part number 18 (an o-ring) I need to double check and degrease everything to tell for sure, but I so far have not seen it.
Any input on locating part number 12 (42036-1005 Sleeve, Rear hub coupler) would be greatly appreciated!
1977 kz650 c1
- tinlizzie37
17 May 2009 18:51
Hi Hardrock, I believe I have a spacer for a 77 KZ 650, but don't know if it's a B or C model. It had wire spokes on it. The spacer should fit between the two bearings with the snap ring installed with no lateral movement.If you can't get the snap ring on, then it's too long. Let me know if you want it. It's yours for the postage, if I can find it. The spacers you show are the outer one for the brake side. Bob U
Bob KZ 650 E1, En 450
