Wheel issue?
- franknsr
Wheel issue?
07 May 2009 17:55
Hey fellow KZ Riders, I come to you hat in hand looking for more advice.
I just got the tire on my new (used) wheel, from a 1978 650 I believe, and it doesn’t line up. I’ve got a 78 speedo drive and axle but the thing appears to be too narrow by about 5-6 mm. Everything forward of the neck is 78 except the caliper.
The forks appear to be straight and I sighted down the side fork tubes as best I can and everything seems good there.
Checked the parts drawings and it looks like I have the correct spacer on the other side. I’m running a single rotor like the CSR and the caliper lines up just fine. An additional rotor will not add any thinckness to the assembly because the axle doesn't touch it.
Is there a small spacer I’ve missed somewhere?
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- PLUMMEN
Re: Wheel issue?
07 May 2009 18:00
can you post picture of what youve got?
- franknsr
Re: Wheel issue?
07 May 2009 18:10
PLUMMEN wrote:
Yea, I still got one of these hangin out at the house.....
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- franknsr
Re: Wheel issue?
07 May 2009 18:11
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- franknsr
Re: Wheel issue?
07 May 2009 18:12
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- PLUMMEN
Re: Wheel issue?
07 May 2009 19:50
are those the same spacers that came off your old wheel? ive still got your old hub in the box i havent opened yet,i can look to see if one of your spacers got thrown in there
- gorack
Re: Wheel issue?
08 May 2009 08:37
did you try pushing the fork leg in it will probaly pop right in to place just a thought,cuz when itook my wheel off it did the same thing and ijust pushed the fork and it popped right on
- franknsr
Re: Wheel issue?
08 May 2009 15:45
PLUMMEN wrote:
This is different axle that I picked up with the spacer. The old wheel was an 82 with a different axle size, but good thinkin.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- franknsr
Re: Wheel issue?
08 May 2009 15:46
gorack wrote:
Yea, kinda tried that but it doesn't want to go that far without forcing it. Something's just not right. Maybe it's me? :blink:
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- PLUMMEN
Re: Wheel issue?
08 May 2009 17:40
whats the center to center distance on your triple trees where fork tubes go through?
- franknsr
Re: Wheel issue?
09 May 2009 05:28
Using the crude tools we have available here on the island of frank and my good eye, it appears to be 83 mm.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- gane
Re: Wheel issue?
09 May 2009 19:00
Csr, A couple thoughts, The (nuts) which fit axle to lower legs are inletted to recieve axle on their inboard sides. thus reversing is not an option. however, placing washers/spacers outside of speedo drive and r/h spacer are. Important things to note are that axle is properly torqued, wheel is centered, disc & caliper spacing is correct....As with most mods, It's best to mark things up.and in the future do your' own fitment. luck G
[img][/img] 1977 KZ1000A1
