Handlebar question
  • n8rade
  • n8rade's Avatar Topic Author
Handlebar question
27 Apr 2009 13:17
#285726
Hello!
Looking in to some superbike bars...currently running the mini ape wrist killer carpal tunnel tendonitus bars...
riding a 1982 kz750 H3(ltd)
anyone had issues running the stock cables with the superbikes?
I've read (while searching) that some had noted getting shorter cables...
I'd just assume not if I can safely get away with it.
Any experiences appreciated.
Looking to get these along with new tires...so i can finally ride comfortably...and without tire worries.
  • timebomb33
  • timebomb33's Avatar
Re: Handlebar question
27 Apr 2009 14:42
#285762
you could probably run the stock cables but they will stick out at wierd angles and they will have wierd bends to them so cable life will be shortened and possibly cause them to break.
I THINK MY POWERBAND BROKE
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
27 Apr 2009 15:06
#285772
Z1 Enterprises sells cables pretty cheap and they will tell you what model to get if you want like 2" shorter or something to fit the superbikes. I just put drags on the 1000 I recently got for nothing. Prolly head over there when I sell the 36mm flatties and Metmachex swinger.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • kztee
  • kztee's Avatar
  • TeeRoy
27 Apr 2009 17:48
#285812
Been running superbike bars on my '80 750 Ltd for a couple years now. The cables and brakes lines stick out a little but they work fine. One of these days I will get around to switching the out with shorter ones. Prolly go with SS brake lines when I do.
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
  • n8rade
27 Apr 2009 20:34
#285867
thanks all.
was looking at the z1enterprises site anyway.
probably be best to just get everything at once.
thanks again!
ride safe!
  • Kwschin
  • Kwschin's Avatar
29 Apr 2009 15:27
#286318
Probably a dumb question, "What are superbike bars?"
  • SheffieldSteel
  • SheffieldSteel's Avatar
  • KZ750E 1981
29 Apr 2009 15:29
#286319
Clamp-ons
My bike is a 1981 KZ750E with Honda VFR400 NC30 single sided swingarm and Aprilia RS125GP rear subframe and seat pods, engine in more pieces than my mind
  • AXL
  • AXL's Avatar
29 Apr 2009 15:47
#286325
My very first Kaw experience was back in 1979. I built my very first Z1E900 chopper. Custom hardtail frame. Beach bars and stock grips. Its the handle bar grips that KILL your hands/transfer all the vibration of a hard mounted drive train to your hands. Get a good pair of foam or soft rubber grips to stop the vibration transfer to your hands. This will eliminate the hand numbing, hand killing feeling.
