kawasaki kz650 csr steering lock
- shitimdumb
17 Apr 2009 00:07
Looking for a little noobie help here. I bought a 1981 kz650 CSR which was delivered to my residence in working order, the original owner showed me how to lock, and unlock the steering column. It's in great shape. Cool. I came the next day to check it out a little more, unlocked the column, and locked it again. Now I can't unlock it. I sat there for literally 20 minutes trying to unlock the bike, came back another day, tried again no luck. Tried the key both ways, moved the handlebars while trying to unlock it. Can you guys give me any idea/clues what it could be? From what I can tell I'm just dumb as hell. Help. I want to ride my motorcycle! >:l
- BSKZ650
Re: kawasaki kz650 csr steering lock
17 Apr 2009 05:38
welcome, first off, I would not use the steering lock, they do hang up, and if someone really wants, a good hard pull will break it.
you might try shooting some penatrating oil in it, they get rusty real easy, and for the most part you will need to hold your mouth in the right position to get it to unlock
77 ltd1000, current rider
76 kz900, just waiting
- Bluemeanie
17 Apr 2009 06:11 - 17 Apr 2009 06:11
When trying to unlock (or lock) turn the key and then move bars gently and a little in each direction. Don't over due the moving bar part. And as above, I don't use mine either.
Last edit: 17 Apr 2009 06:11 by Bluemeanie.
- JMKZHI
- shitimdumb
19 Apr 2009 21:37
Well I'll give the more gentle and oiled approach a try. Thanks for your input guys, really comforting knowing I have a community here to guide me. What's involved in fixing this if I have no luck with the tips given here?
- MFolks
19 Apr 2009 21:49
You might have to lower the headlight and replace the ignition switch/fork lock as a unit. I think some metric allen screws hold it into the bracket.
- RonKZ650
20 Apr 2009 06:58
It takes 10 seconds to "fix" this. Grab the handlebars and turn them till the lock breaks. This is if it's the lock on the frame. If the lock is part of your ignition switch, I've never tried "fixing" that type. Buying junk bikes that the keys are missing with the steering locked, I've done a few of these.
- JMKZHI
20 Apr 2009 07:44
The lock is integrated into the ignition switch.
Push & turn counter-clockwise to lock.
Push & turn clockwise to unlock.
- boots
20 Apr 2009 14:23
And if that don't work, get a big hammer!! LOL
Boots
Boots
present bikes 1976 KZ900, 1978 KZ650 Past bikes Too many to remember!!Mostly Kawasakis and a few Sportsters
81 cb650
81 cb650
- KawiConvert
20 Apr 2009 19:19
I cut mine off early on as it looked like it would cause havoc with my headlight position. Haven't missed it sense. Also noticed when cutting it, like others have said, the one in the steer tube is pretty flimsy.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- shitimdumb
21 Apr 2009 16:07
Could you describe where it is in relation to an obvious part, possibly a picture?
- KawiConvert
21 Apr 2009 22:58
shitimdumb wrote:
I can only show you where it was. Where it is now is somewhere out in the county landfill (the lock that is). The old mount is circled in red. It had a flimsy cover over it at one point.
