Fork disassembly help needed
  • Alabaster
  • Alabaster's Avatar Topic Author
  • Dallas, TX
12 Apr 2009 17:36
#281121
I'm trying to replace the seals in my KZ1000. Of course, the allen head bolts are spinning. Can someone link me to the thread about the "broom handle" method or briefly let me know the specifics? Thank you in advance. This is getting very tiresome without a second set of hands. :P
'07 Ducati SC1000S
'79 KZ1000
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Fork disassembly help needed
12 Apr 2009 17:40
#281123
if you have access to a compressor and air ratchet that normally will spin them out B)
  • Alabaster
  • Dallas, TX
12 Apr 2009 17:47
#281129
I have an allen wrench in my electric drill. It's spinning it pretty fast. I've tried compressing the fork, I've tried pulling it. It's just spinning. What can I put on the end of extensions down the tube to stop the piston from spinning?
'07 Ducati SC1000S
'79 KZ1000
  • PLUMMEN
  • PLUMMEN's Avatar
12 Apr 2009 18:26
#281154
well i guess you could use the ol broom handle spear trick and shove it down there to hold it.B)
  • Alabaster
  • Dallas, TX
12 Apr 2009 18:39
#281162
well, I didn't have any brooms with wooden handles, all plastic. But I did have an old pool stick with a broken tip. I squared off the end nice and smooth and shoved it down in there. Only slipping. I used ratchet tied downs to keep it in there nice and tight. Still slipping. I don't know what to do short of buying the Kawasaki tool that is designed for this job. I saw a thread where someone used a 22mm bolt head and it fit tight. Would this work on a 79 model?
'07 Ducati SC1000S
'79 KZ1000
  • timebomb33
  • timebomb33's Avatar
12 Apr 2009 18:48
#281167
try using a 17mm nut welded on to a piece of rod or all thread up here some of us call it ready rod. aand put a t handle on it so you can hold it a drill won't work for this kind of operation only a impact or use the t- handle you just built and a breaker bar.
I THINK MY POWERBAND BROKE
  • Alabaster
  • Dallas, TX
12 Apr 2009 18:51
#281170
so a 17mm is the right size for the '79 KZ1000? Thank you, I'll pick one up at the auto parts store tomorrow.
'07 Ducati SC1000S
'79 KZ1000
  • dman3998
  • dman3998's Avatar
12 Apr 2009 18:55
#281173
I made that tool with a bolt welded into a 1/2" pipe. I clamp it into the vise, slide the fork tube over it and spin out the bottom Allen bolt easy.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
  • timebomb33
12 Apr 2009 19:00
#281177
that is a great idea as well i never thought of that trick see even an old dog can learn a new trick every now and then thanks for thatbit of wisdom.
  • taildragger1197
  • taildragger1197's Avatar
12 Apr 2009 19:26
#281197
I have always used an air impact wrench. Just turn the pressure up as high as it is rated and let it spin. It may take a moment but it will work. I have rebuilt several this way and have seen several mechanics use this method. An electric drill won't spin fast enough or have the torque required. Don't waste your money on a factory tool.
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
  • Alabaster
  • Dallas, TX
12 Apr 2009 19:34
#281203
So if I just put the impact wrench on it the high rpm's will spin it free?
'07 Ducati SC1000S
'79 KZ1000
  • taildragger1197
12 Apr 2009 19:39
#281209
exactly
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
