What can or can't be used?
  • KF4ZHT
  • KF4ZHT's Avatar Topic Author
06 Apr 2009 19:23
#279031
Hi yall,
posted a couple of questions over in electrical and got great help, so I figure the next place I need help is over here.
I just picked up a 77 kx650c1 in a trade. There was a fuel fire that burned up the wiring harness (the main problem) and the bike has been a project for a while. There are a few other things missing though that I need, I was wondering if these needed to be gotten from a 77 or if any 650 would work:
1. Air box - most likely lost in fire
2. Battery Tray (I may fab one up)
3. Side farings
4. Rear master cylinder (pedal, lines and switch are there)
5. Front master cylinder (I know these had a round resvoir, will a square work?)
That is all I found for now, I am making lists of what and where to buy.
Re: What can or can't be used?
06 Apr 2009 20:36
#279065
Not any front KZ650 M/C will work. You need to get one from a bike with dual front disks; the single disk M/C's are different internally even though they look the same outside.
  • Mark Wing
  • Mark Wing's Avatar
06 Apr 2009 21:18
#279073
1. From 77 to 79 should work.
2. any year
3. 77 78 C or B
4. any year with disc
5. like said.
Mark
Yorba Linda Cal.
  • KF4ZHT
07 Apr 2009 04:48
#279133
2. any year
3. 77 78 C or B
5. like said.
Mark
Exactly what I needed.
Yeah, I figured on the dual brake system the cylinder would probably have a bigger bore.
The hardest problem I have had is the brake cylinders. The fronts go for a bunch of money even used and the rears are just plain hard to find.
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
07 Apr 2009 05:00
#279134
One thing to keep in mind is that the 77 650 C-1 used 2 different types of rear caliper. The first 10,000 or so made used one type and then there was a mid production changeover to another type. It won't make any difference as long as you buy the entire caliper and mounting setup but buying just a caliper you need to pay attention.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • KF4ZHT
07 Apr 2009 07:13
#279156
I haven't pulled the caliper yet, but is this only the caliper, or is it the MC also?
I can weld/fab so making brackets isn't that big a deal if I have to.
  • The Gringo
07 Apr 2009 07:44
#279162
It is only the caliper that is different. The early ones used the puck shaped pads and the later ones went to a square pad. I just figured I'd bring it to your attention to save you some screwing around.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
08 Apr 2009 07:10
#279477
Welcome and nice find.
I thought the suared rear pads did not come out until 1979 (or '78 on the D models).
My '78 C2 has the round rear pads, but my C3 had the square.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • The Gringo
08 Apr 2009 08:47
#279503
I just checked the Kawasaki site and apparently my memory isn't as good as I thought. The early style pad was used for the first 23,100 bikes after which they went to the square type pad.
Rob it's odd that your 78 came with the older style caliper, the only thing I can think of is that your bike is a Canadian unit. Kawasaki probably figured they'd sell a few more there if the pad was shaped like a hockey puck.:laugh:
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
