Old sprocket, time for a new one?
- chupinator
20 Mar 2009 23:16
I don't know too much about motorcycle sprockets, but this just doesn't look right. How often do you change your chain and sprockets? When I took my rear wheel off there was probably an inch and a half of chain play, with the adjuster maxed out. I think its the original chain and sprockets with about 16,000 miles and 32 years. I'd say its about time.
1976 KZ900 A4
- smithgpz
Re: Old sprocket, time for a new one?
21 Mar 2009 01:17
that is way past due for replacement.always replace sprockets and chain as a set.
- chupinator
21 Mar 2009 01:31
Damn, I was just looking for an excuse to keep that $120 in my pocket. Looks like I need to deliver more pizza.
1976 KZ900 A4
- kpier998
21 Mar 2009 04:48
A good welder could fix that sprocket for you no problem. Or you can just use JB Weld. I don't see why you want to waste a perfectly good piece of metal.
- mumbles
- Let's do it...
21 Mar 2009 05:21
Judging from the picture my old sprocket probably had about 10k miles left on her.:lol:
2001 KZ1000 Police
1998 Vulcan 800
Houston, Tx
1998 Vulcan 800
Houston, Tx
- Bluemeanie
21 Mar 2009 05:41
Pop the clutch a couple times and you could smooth that right out!! :woohoo:
- Old Man Rock
21 Mar 2009 07:22A good welder could fix that sprocket for you no problem. Or you can just use JB Weld.
:ohmy: :huh: :blink: :blink: :blink: :blink:
Please say you're joking...right????
:laugh: :laugh: :laugh: :laugh: :laugh:
Deliver more pizzas to buy new chain & rear sprocket....
Question, hows the front counter sprocket look?
Chances are that's toast as well...
Deliver even more pizzas to buy new chain & rear sprocket.... & front counter sprocket....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- RonKZ650
21 Mar 2009 07:31
Someone "forgot" to oil the chain on that one. Guys that say no need to oil take note.
- chupinator
21 Mar 2009 09:41
Bluemeanie wrote:
Yeah, my end of the year burnout did have a nice clunking noise to it. :blink:Pop the clutch a couple times and you could smooth that right out!! :woohoo:
1976 KZ900 A4
- H2RICK
- Is this a fun bike, or what!!!
21 Mar 2009 22:35
Well, that sprocket in the pic is now #2 on my all-time list of "Bad Sprockets I Have Seen". The top-of-the-list sprocket had "teeth" that were about 2/3 the height of the ones in the pic. The owner of that bike said he had this strange whirring noise when he tried to pull away from a stop.....and had to paddle the bike and feather the clutch until it would finally "catch" and stop whirring.
Chupinator, you've made my day.:laugh: :laugh: :laugh:
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- trianglelaguna
22 Mar 2009 06:20
speechless....blind bravery....bet you can never ride again not thinking about you chain....once you know the difference there is no going back....you got a free pass on that one.....really not safe....good luck....live long and prosper!!! without thinking
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
22 Mar 2009 06:45 - 22 Mar 2009 06:50
Chupinator wrote "I don't know too much about motorcycle sprockets...."
Not trying to take a poke at you, but truer words were never spoken if you honestly aren't sure that this sprocket is shot. Sprockets are suppose to have teeth, yours barely has gums. :laugh: Take a look at a new sprocket. Sprockets should be replaced if there is noticable wear. Be sure to replace both sprockets and the chain together. Be sure to lube the new chain every few hundred miles; my prefered lube is a product called "Chain Wax." With only 16,000 miles it's obvious your chain was not maintained. I replaced mine at 36,000 miles after 25 years and the sprockets looked new compared to the one in the picture. Ed
Last edit: 22 Mar 2009 06:50 by 650ed.
