What swingarms will fit on the KZ?
  • Mercymac
  • Mercymac's Avatar Topic Author
14 Mar 2009 04:30
#271800
I have a 1976 KZ 900. I am going to try to convert the back brakes into disc brakes, and i would like to put a different swing arm on it, What kinds of swing arms will fit on the KZ?
"If you dont know where you're going, its hard to get there.."
  • Old Man Rock
  • Old Man Rock's Avatar
Re: What swingarms will fit on the KZ?
14 Mar 2009 07:20
#271839
As others have provided, 1981 (I think) Suzuki GS1100 is about the only one I've heard of where minimal mos are required...
From others, maybe a spacer or modified bearing but pretty much a direct fit...
You know it's weird, I don't see where more Honda or Yamaha conversion parts are used.... Interesting...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Mercymac
14 Mar 2009 07:26
#271842
OMR, What kind of swingarm, monoshock system do you have on your 1976?
  • smithgpz
  • smithgpz's Avatar
14 Mar 2009 07:29
#271843
old man i right.the suzuki gs1100 arm is the most common.that is what i use.they fit with no mods just a small spacer on each side of the pivot shaft.this will keep the dual shock setup and that is what i prefer on a old kz. here is a pic of the z i'm building now with a gs arm.this will also alow you to go to rear disc.these arm come up on ebay all the time and normaly sell for $75-125.
  • Old Man Rock
14 Mar 2009 07:34
#271845
2003/2004 ZX6RR J link mono....
Requires a considerable amount of modification..... Not only for swing arm mounting but for battery/electrical as well....
And before getting even starting, definitely think about offset & rear sprockets, chain path, rim/tire etc... ;)
members.cox.net/ruinsofstei/Old%20Man%20...Arm%20Conversion.pdf
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • bigwill5686
  • bigwill5686's Avatar
14 Mar 2009 09:47
#271867
How much longer is the gs1100 swingarm over stock?
77 kz1000 ltd- 4 into 1 kerker, 1075, dana ignaiton, cams and carbs and head work done...
1999 busa- 4 into 1 yokomo, k&n intake, power comander.....
  • PLUMMEN
  • PLUMMEN's Avatar
14 Mar 2009 09:50
#271868
around 1 1/2"B)
  • kzz1p
  • kzz1p's Avatar
  • One Test Is Worth A Thousand Expert Opinions!
14 Mar 2009 10:07
#271870
About how much wider?
  • donthekawguy
  • donthekawguy's Avatar
14 Mar 2009 16:21
#271914
I believe you can fit a 180 tire in the gs arm. I have a 140 on mine and have plenty of room for a bigger tire. Next year I'm going up to a 170.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • otakar
  • otakar's Avatar
14 Mar 2009 16:32
#271918
The ZR750 and ZR1100 Zephyr swing arms also fit quite nicely, though they are much more rare.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • smithgpz
  • smithgpz's Avatar
14 Mar 2009 16:39
#271925
i'm putting a 180 on mine.i think thats the biggest you can use.
  • otakar
  • otakar's Avatar
14 Mar 2009 16:54
#271928
With a wheel that big, do you have to use offset sprockets? I have a 140 on mine and the chain comes pretty close to the tire.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
