What swingarms will fit on the KZ?
- smithgpz
- timebomb33
Re: What swingarms will fit on the KZ?
14 Mar 2009 17:39
i have a older zx-7 swingarm on one of my older conversions the style that uses the eccentric adjusters and it wasn't to bad to switch over and it gave the wheel base an extra 2 inches all i did was make a mount for the tourque arm and cut the mono shock linkage mounts off and flippthem around and remount them on the top for shock mounts. i also have a gs 1100 setup on my little drag bike and it was very easy to convert. for racing i like the gs arm but for looks on the street the zx arm is pretty cool.
I THINK MY POWERBAND BROKE
- otakar
14 Mar 2009 18:19
What did you do for the shock mounts on the ZX7 arm? Did you just ark on a set for standard duals?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- timebomb33
14 Mar 2009 18:44
i took the mono shock linkage mounts of the bottom of the swingarm and flipped them around and located them on the upper side of the swingarm and welded them in place they were a perfect fit for the shocks that way i didn't have to make anything else up and they are very beefy it worked out perfect as they are made out of the same alluminium as the swingarm so we didn't have to try to weld disimalar types of metal together so it made it very strong. win win situation
- zippy
14 Mar 2009 20:21
smithgpz wrote:
Shocks ??? Shocks you say ??? - For god's sake man - Real men don't use shocks !!!!
old man i right.the suzuki gs1100 arm is the most common.that is what i use.they fit with no mods just a small spacer on each side of the pivot shaft.this will keep the dual shock setup and that is what i prefer on a old kz.
- otakar
14 Mar 2009 20:27 - 14 Mar 2009 20:30
zippy wrote:
Ouch :ohmy: I'm too old to loose my kidneys, and I like my other organs just where they are. NO THANK YOU
I've been and survived too much combat to loose body parts now. If the rag heads couldn't kill this old Marine I sure wont let my Kaw do it.
smithgpz wrote:old man i right.the suzuki gs1100 arm is the most common.that is what i use.they fit with no mods just a small spacer on each side of the pivot shaft.this will keep the dual shock setup and that is what i prefer on a old kz.
Shocks ??? Shocks you say ??? - For god's sake man - Real men don't use shocks !!!!![]()
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Mar 2009 20:30 by otakar.
- smithgpz
15 Mar 2009 01:32
call me a sissy, butt struts on the street is just nutts.:S
- timebomb33
15 Mar 2009 07:47
why is that, guys are willing pay 50 to 70,000 dollars for them all the time from these so called bike builders. zippy is just doing it on the cheap to get the same effect.
- Old Man Rock
15 Mar 2009 08:13butt struts
Quick, sell them on e-bay... BUTT STRUTS for sale, starting bid $200 or buy now for $300.... :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
15 Mar 2009 08:49
timebomb33 wrote:
"A fool and his money are easily parted" I could never understand how someone could PAY for a bike like that. There is nothing to be proud of. Just proof that you are a rich FOOL. Now on the other hand, if you build your own bike and set the value at that sum, you are now a skilled craftsman and can be proud of what you accomplished. But to loose body organs for the sake of stiling is just not for me. I want to be able to ride till I'm at least 85+++ :woohoo:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Mercymac
25 Mar 2009 06:08
Ok, now call me stupid, but can you fit the 180 tire on the factory rim? or in my case I have a ninja 250 rim on my bike. Whats the biggest tire you can fit on a stock rim?
"If you dont know where you're going, its hard to get there.."
- Mercymac
25 Mar 2009 06:11
WOW!! never mind i'm a retard, disregard that last post but what is the largest tire you can fit on a 3.5 rim width?? like 150 ish??
