fork slugs????
  • gane
  • gane's Avatar
Re: fork slugs????
06 Mar 2009 20:54
#270144
See no prob. Cosmetic's seem same, Valving may be diffent, but cosidering present changes easily within peramaters. More. G
[img][/img] 1977 KZ1000A1
  • racer54
  • racer54's Avatar
Re: fork slugs????
06 Mar 2009 21:51
#270154
Putting a slug, or spacer on top of your springs will stiffen the fork compression up. You will only be able to put so much in there before you wouldn't be able to get the fork cap back on though. To lower the ride height, you can take the fork tubes apart and place a spacer underneath the spring you will find on the lower tube inside the fork leg. You can buy these in 1", 2" or 3" and they will lower your ride height by that amount. People have made these out of pipe cut to length and even PVC tube. Anything rigid or hard enough to rwithstand the load. Or you can use H2 fork tubes from the earlier models. Not sure if they are all as short but the 72 model fork tubes are about 1 1/2" shorter. I have them on my bikes so I can reach the ground better.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: fork slugs????
07 Mar 2009 06:04
#270181
PLUMMEN wrote:
put some 650 forks on a 900/1000 B)
You could just drop 650 springs in 1000 tubes...drops the front end about two inches (I know this because I acquired an entire 1978 KZ1000A2 front end (w/650 springs in it) and installed it on my KZ1000A1...didn't like it and replaced the springs w/the original 1000 springs).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • gaillarry
  • gaillarry's Avatar
Re: fork slugs????
19 Mar 2009 04:24
#273321
tachrev wrote:
Doing that will stiffen things up, but you have to watch how much you cut or you could run into problems bottoming out the forks/binding the springs.
Check this out, I think it describes exactly what you are trying to do.
[url=
www.calsci.com/motorcycleinfo/Suspension...]Lowering/Stiffening Fork Springs Worksheet[/url]
Anyone have the correct link, this one's not working.
1977 KZ1000
1985 Gpz750
  • tachrev
  • tachrev's Avatar
  • Rubber Side Goes Down
Re: fork slugs????
19 Mar 2009 06:18
#273352
[url=
www.calsci.com/motorcycleinfo/Suspension2.html
Here you go, sorry about that.
Build Thread
  • PLUMMEN
  • PLUMMEN's Avatar
Re: fork slugs????
19 Mar 2009 11:19
#273402
the 650 tubes are actually shorter i do believe B)
  • 77street
  • 77street's Avatar
Re: fork slugs????
21 Mar 2009 20:46
#274057
just to add my .7 cents.. I run a 650 with a gpz550 frontend with air assist but it was two soft and I discovered a perfect spacer is u joint caps from a dana 30 (I'm a jeep guy the rest of the time :) it seems lots better now but I haven't ridden alot yet this year still got snow here..
