Need tires for z1 with Lesters......
Re: Need tires for z1 with Lesters......
03 Mar 2009 12:30
z19OO wrote:
The outside rim width of the Lesters on my 1973 Z1 measure just slightly over 2 13/16ths inches, both front and rear.
The inside rim width between lips would of course be more meaningful, but impossible (for me) to measure with tires mounted.
Wasn't aware that Z1 rear drum Lesters also came in a 3 inch rim.
Those are handsome tires!
Good Luck!
... Do you know if the Lester front rim is a 2.15 or 1.85?....
Good Luck!
- z19OO
03 Mar 2009 13:12
Yeah, I checked the width after I ordered the tires
my front rim is a 2.15 also but has a big 4.10-19 tire on it!
Thanks!
Thanks!
1975 z1 900
1979 kz650b
1979 kz650b
- Russ Jackson
03 Mar 2009 13:26
Patton wrote:
I will measure both my front and rear tonite and post a picture. Where should I measure?...Russ
z19OO wrote:... Do you know if the Lester front rim is a 2.15 or 1.85?....
Good Luck!
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- z19OO
03 Mar 2009 14:46
Russ, Look on the one of the spokes.....should tell you the size like 2.15x18.
1975 z1 900
1979 kz650b
1979 kz650b
- Russ Jackson
03 Mar 2009 16:07 - 03 Mar 2009 16:07
It Says 18 X 2.15...Russ
Last edit: 03 Mar 2009 16:07 by Russ Jackson.
03 Mar 2009 20:09 - 03 Mar 2009 20:14
On left (chain) side of rear Lester on my Z1 has "18x2.15TL DOT" in tiny lettering imprinted on one "spoke." This being the rim with outside width slightly over 2 13/16 inches.
The 19" front Lester with same outside rim width slightly over 2 13/16ths inches had no visible markings. But with same outside rim width as rear, would assume same 2.15 inside width as rear.
Maybe I don't need tubes after all. :ohmy:
Good Luck!
Good Luck!
Last edit: 03 Mar 2009 20:14 by Patton.
