gpz/kz whel swap?
  • lewisj
  • lewisj's Avatar Topic Author
gpz/kz whel swap?
18 Feb 2009 16:59
#265993
Does anyone have knowledge about swapping a rear GPZ wheel to a z1 swingarm? The size of the rim is correct but I am not sure about the hub assembly. Any help would be appreciated. Thanks Lewie
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: gpz/kz whel swap?
18 Feb 2009 17:06
#266000
Paul (pz1morton) may be able to help you.
He's got GPz wheels on his KZ650, and owns a few Z1/kz1000s as well:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • otakar
  • otakar's Avatar
18 Feb 2009 17:16 - 18 Feb 2009 17:18
#266004
The KZ650/750/900/1000/1100 1973-1982 all had the same swing arm dimensions. As long as you are going from a rear disc to a rear disc it is a simple swap. There was a slight difference on the inter gusset when the bike used a 16" wheel but even these will work. If hoever you are talking about a 83 or later wheel that I do not know.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 18 Feb 2009 17:18 by otakar.
  • Bdog
  • Bdog's Avatar
  • Sweep the leg johnny!!!
18 Feb 2009 17:18
#266006
My 650 had a gpz750 rear wheel in the stock 'arm. I believe a gpz1100 wheel will fit, the bushings will have to be turned down a little. To accomadate(?) the heb thickness. I don't remember what mine was, but it also fit the 1000 swinger that I am using, but the axle shaft bearings are bigger on the 1100.
Hope that helps some.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
  • lewisj
18 Feb 2009 17:38
#266013
Thanks bdog and otto!! Sounds like only the bushings need to be adapted, if at all. Appreciate the help!
Lewie
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
  • pz1morton
  • pz1morton's Avatar
18 Feb 2009 20:20
#266073
Hi Lewis
well what i have on my bike is a 82 gpz750 rear swing arm which is almost the same as a z1's, just alittle longer.but to answer your question it should fit no problem as long as you are going with disc set up also you will have to use the gpz hub and bushings or go with the z1 hub and play with the bushing also be careful of rear wheel alignment,and your chain alignment.other than that you should be good to go.if any problems let me know.send me an e-mail.B)
Regards Paul
1975 Z1 X 2 one i've had since new [many thanks to a great dad whos now since past]i've seen my son eyeing it every now and then.has 1075 kit,yosh cams,yosh pipe,29 smthbrs,rearsets.
1978 KZ650C that i race
1984 GPZ900
1972 CB350 building as another race bike
1982 CB750 w/836 kit,yosh cam
  • lewisj
19 Feb 2009 08:01
#266140
Thnks Paul,
I am looking at possibly switching over to an 83 GPZ 550 or 750 wheels. I have rear sets that will align nicely to the rear disk set up. I have an aftermarket "MR. Turbo" swingarm that is the same length and width as stock, just much beefier and stronger. I can get the GPZ wheels with Disc's for a good price and just wondered if the swap would be much trouble. Thanks for the info!!
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
