New GS Swingarm - Need axle
- gane
Re: New GS Swingarm - Need axle
17 Jan 2009 20:21
As usual, after winning bid on GS swing arm anouther comes along, item # 1302810007006 w/bits.currently @ a $100.00 G
[img][/img] 1977 KZ1000A1
- otakar
18 Jan 2009 08:15
I used a Axle from a KZ1300. You can buy the new pretty cheep or do like I did, get one off of eBay. They fit perfectly.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
18 Jan 2009 08:17
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- roy-b-boy-b
21 Jan 2009 14:43
What is the measurment of the diameterof the axle.
The one i have is 20mm dia. X 13 3/4 inches.
It is hollow Roy
It is hollow Roy
- kztee
- TeeRoy
21 Jan 2009 15:38
I know most people that do this swap use Suzuki shocks. I got some but the upper shock mount doesn't fit. The stud is too big (or the hole is too small). What is the best way to remedy this?
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- otakar
21 Jan 2009 17:09
The shocks I have on mine are made for a GoldWing:angry: Dirty word I know but they are perfect. I bought the same Suzuki shocks and had the same problem. The GS swing arm has the mounts set a bit farther back because it is longer. This gives the bike a "Squaty" appearance. The GW shocks are an inch longer and make the bike look right, and handle much better.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kztee
- TeeRoy
21 Jan 2009 17:33
And the GW shocks fit without any mods?
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
- otakar
24 Jan 2009 08:47 - 24 Jan 2009 08:51
The shocks were a direct bolt on. Took about ten minutes to mount them. Because the GS swingarm is a bit wider I put a couple spacers between the frame and eye to bring them out about 3/16 on each side. The shocks I bought at BikeBandit.com I can give you the part # if you are interested.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 Jan 2009 08:51 by otakar.
