New GS Swingarm - Need axle
  • kztee
  • kztee's Avatar Topic Author
  • TeeRoy
07 Jan 2009 19:16
#256636
I am in the process of getting everything mocked up on my 77 1000. I bought a swingarm on ebay last April from a GS1100. The arm did not come with a rear axle. I do not know the year of the bike it came off of. Does anyone know where I can find the proper rear axle? Will any GS axle work aslong as it is long enough?
1977 KZ 1000A - Currently rebuilding
1980 KZ 750 LTD - Mostly stock daily rider
1979 KZ 1000 LTD - Parts bike and/or future project
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
  • PLUMMEN
  • PLUMMEN's Avatar
Re: New GS Swingarm - Need axle
07 Jan 2009 20:18
#256645
have you tried your kz axle?;)
  • donthekawguy
  • donthekawguy's Avatar
08 Jan 2009 00:09 - 08 Jan 2009 00:10
#256666
I think the kz axle is not long enough. I'm doing the same swap on my 77 right now. The axle that came with the arm was so messed up I had to get a new one. I used one of the wrecking yard parts locators and found 3 of them by the next day. Prices are around 20-25 bucks plus shipping. Just look for a 81-83 gs1100e axle and you'll be fine. Also be sure to ask if they have the spacers. You might not use them but it's nice to have them. I lucked out and found a spoked gs wheel with a 5.5 inch akront rim on ebay. Should make the whole thing very easy when I get around to putting it together. Or if you have some way of rethreading the axle I could send you the one that I have laying around before I throw it out. PM me.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Last edit: 08 Jan 2009 00:10 by donthekawguy.
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
13 Jan 2009 08:52
#257654
I had the same problem , But wasnt able to find a used one , So I got a new one from the dealer ,, also a new nut Gs1100E is all I asked for
  • kztee
  • TeeRoy
13 Jan 2009 16:47
#257723
Don is helping me out with this by sending me his messed up one that I will try to fix. If that doesn't work there are some used ones on ebay. How much did that run ya, Shoe?
1979 KZ 1000 ST
1980 GS 750 L
2003 ZRX 1200 R
  • circusnuts
  • circusnuts's Avatar
13 Jan 2009 17:43
#257747
Any of you fine folks have pictures of the installed GS swing arms? I've been kicking around making a change, but nothing as drastic as the after market ones. My bike is pretty much stock & it looks really good, but wouldn't mind adding a little wider tire f'sho.
  • donthekawguy
13 Jan 2009 23:35
#257792
I just posted pic of my install. Look for and so it begins under donthekawguy.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • gane
  • gane's Avatar
14 Jan 2009 15:32
#257898
K, I just measured (via straight edges and welding rod)outside widths at chain adjusters my "81 GS1100E swingarm. 11 1/8 inches. Hope this helps G
[img][/img] 1977 KZ1000A1
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
14 Jan 2009 17:04 - 14 Jan 2009 17:05
#257911
I parted out two GS bikes a couple of years ago. I'll try and remember to look. I don't like to go to the shop in the winter. I'm a wimp:blush: Roy
Last edit: 14 Jan 2009 17:05 by roy-b-boy-b.
  • Shoe48
  • Shoe48's Avatar
15 Jan 2009 15:38
#258103
it was in the 30.00 range
  • headspace
  • headspace's Avatar
16 Jan 2009 04:26
#258203
What is the overall lenght end to end of the axle?
1975 Z1 900 (1015)
1976 KZ900 (dragbike project)
  • gane
  • gane's Avatar
17 Jan 2009 20:12
#258494
From sw/arm to end an additional 1 3/8 inch. thus derived, 13" of shaft + HEAD. G
