risers available?
  • cnyl
  • cnyl's Avatar Topic Author
risers available?
19 Dec 2008 18:59
#253606
Hi guys.
I'm trying to find risers to raise my drag bars up so I can use a zx9r front brake and master cyl. I'm looking to go 1" to 2". Anybody got a linky?
Thanks;)
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
  • wiredgeorge
  • wiredgeorge's Avatar
Re: risers available?
20 Dec 2008 11:11
#253693
www.zianet.com/GenMar/
Look at the universal 1" rise or they have one that has both rise and pullback. I bought a set these 1" risers for the Bandit I used to own.
  • cnyl
20 Dec 2008 14:29 - 20 Dec 2008 14:31
#253719
Thanks wg! Perfect!;) I couldn't find em anywhere.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
Last edit: 20 Dec 2008 14:31 by cnyl.
  • wiredgeorge
20 Dec 2008 16:06
#253730
They have risers come up on eBay all the time. At one time, they were pretty popular on metric bikes to raise or move back the bars. Many new bikes can't use this type riser due to over complicated handlebar engineering. Clip ons and funky bars like on my Goldwing. Genmar is the LEADING company making this type stuff and very popular with the Connie riders. I let a set of risers with 2" rise and 1" pullback go with my Bandit that I sold awhile back that were old school. They worked nicely as the mount bolt offset has never really changed for many Kaw and Suz models over the years. Some offsets will require you open up the holes a tad to allow the bolts to go through. Always use stainless and not the steel, zinc plated bolts that come with most risers.
  • PLUMMEN
  • PLUMMEN's Avatar
20 Dec 2008 19:04
#253756
how about just using differant bars?;)
  • Old Man Rock
  • Old Man Rock's Avatar
21 Dec 2008 05:51
#253822
jpcycles has a whole slew of them... downfall, mostly 1" bars and up. Same time, as I went with a Renthal Fat Bar that is 1 1/4" in the middle then tappers off to 7/8" at the bar ends, not a problem.
Old school KZ handlebars are 7/8" throughout. May need some spacers in the clamps if you go this route.
www.jpcycles.com/search.aspx?search=hand...sers&store=Sportbike
There's street/motocross risers that are for 7/8" bars...
www.zeta-racing.com/clamps/bar_rise/index.html
www.twistedthrottle.com/trade/productlist/218/
Just Google 7/8" handlebar risers and a whole slew of links will be provided... All depends on what you're looking for...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • Locozuna
  • Locozuna's Avatar
21 Dec 2008 05:59
#253825
Sometimes you just can't get the right bars. I prefer my wrists not be twisted onto the bars. I have a short set that is almost straight that I really like. The thing that would make them perfect is if they were about an inch higher. I have never found the equivalent in a bar with that extra inch in rise while keeping wrist angle the same. Seems as bars rise they twist the wrist in or down. Especially on the short flat bars, risers are the way to go if you like the bars. $90 seems a little much tho.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • Kawickrice
  • Kawickrice's Avatar
21 Dec 2008 06:03
#253827
Loco what about superbike bars?
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • Old Man Rock
21 Dec 2008 06:06
#253828
I had to go this route anyways due to old ass equates to no clip on's desired on ZX636 fork tubes! The back just wouldn't be able to cut it on a long ride...
Now she's just perfect...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • Locozuna
  • Locozuna's Avatar
21 Dec 2008 07:11
#253846
That's what I have on my 900...Superbike Bars. I like the way they keep my wrists straight and not angled. But they would be a lot better with an extra inch of rise. Maybe 1.5 or even 2 inches would be OK. It would make the brake rez and hoses at a better angle and make the stock cables easier to route without binding too. Been on the lookout for a set of risers. I'm cheap and $90 like I said is steep to me. I'll watch the auctions and clearing houses....might get lucky. But if not I'll prolly bite the bullet in the spring and order those diamond encrusted $90 ones:blink: !
I had some on a old Suzi GS750 bomb I used to have with straight (broomstick like) bars but they had a setback too. Just want risers now.B)
That's the other thing...it gets the bars a little off the top of the fork tubes too. ;)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
  • PLUMMEN
  • PLUMMEN's Avatar
21 Dec 2008 09:20
#253872
check with steel to see if 750 twin has same dimensions on top tree ,i know the twins ive seen have rubber mounted bar mounts/risers so it might be easier to adapt something to one of those triple trees.B)
  • cnyl
21 Dec 2008 12:23
#253903
I really like the drag bars I have. I've used the same kind of bars on many bikes and the risers will solve all my problems with the controls not hitting the tank plus gives me enough room to mount a cbr929 front master cyl and lever. The bike came with superbike bars on it. They felt pretty good but I like the way drag bars look better.lol Oh... The drag bars feel good too.;)
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
