swapping front and rear suspension?
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Re: swapping front and rear suspension?
06 Nov 2008 19:57 - 06 Nov 2008 19:59
#246000
eddieteeth wrote:
i have a guy at work with a torn apart 94 zx7.. if i were to do this swap what kind of fabrication if any is needed..
The front end won't be a big deal; check in other places (in "Projects" ) for the hot set-up on the dos and don'ts. I think you'll have a problem making the swing-arm work b/c the ZX7 swing arm widens out very abruptly from the swing-arm pivot...meaning, the arm will likely be narrow enough at the pivot, but I think the arm itself will 'foul' the frame before the swing-arm pivot hole will be able to line up with the frame pivot hole. :angry:
If anybody has an expedient way around that one I'm all ears.:huh:
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
Last edit: 06 Nov 2008 19:59 by Bad Kaw.
