looking for recommendations for fork swap 1980 ltd
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: looking for recommendations for fork swap 1980 ltd
04 Oct 2008 04:00
#240072
I don't think i have a pic of the bike any more. They are on the hard drive of my fried computer.
All i had to do to the swingarm is remove 3/4 inch off each side of the front of the swingarm.
If i had to to over again i would leave the mono shock off and have two mounting brackets for shocks welded to the swingarm. Roy
  • Genros
  • Genros's Avatar
07 Oct 2008 09:02
#240578
Anybody else on here ever do this mod. DId it improve handling, stance etc.... it sound pretty neat. Ninja and or gixxer parts on a 80 kz1000 sounds like a cool recipe for fun
  • StreetfighterKz
  • StreetfighterKz's Avatar
07 Oct 2008 09:27
#240580
Genros wrote:
Anybody else on here ever do this mod. gixxer parts on a 80 kz1000 sounds like a cool recipe for fun
Type "fork swap" in the box that says "Search Function" in the top right hand corner. I just got 439 results. I'm swapping to newer forks on my 'Stripfighter project but it's not done yet so I haven't road tested it.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • supercharged
  • supercharged's Avatar
07 Oct 2008 09:34
#240582
I'm in the same place, ds390ss123. I want to make the change and even picked up a complete 2006 Gixxer 1000 front end, but time has kept me from going further. I keep looking for someone in the SoCal area that has done a swap to call on for advice, but haven't found one yet.
I did here that turning radius is shortened on the Gixxer swap if you don't fab your own trees... and who does?
I am also investigating the FZR front end swap to stay with conventional forks.
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
  • ds390ss123
  • ds390ss123's Avatar Topic Author
08 Oct 2008 19:32 - 09 Oct 2008 06:37
#240845
I am still investigating the whole route I am taking with the bike. The fellow at redlinecycles has made some strong points against the swap thing. I have NOT ruled it out yet. I am looking for more info and hope to make informed choice soon. One other thing I need to explore is some custom set-up, problem- big $, but this is not ruled out either. Got a cool paint scheme getting worked on now. I am very excited about this project and hope to share my "fun" with you guys as it progresses. thanks...paul
Last edit: 09 Oct 2008 06:37 by ds390ss123.
  • ds390ss123
09 Oct 2008 15:47
#240994
www.roadbikemag.com/forum/MincowKawiKZ1000.php does anyone know if the 1977 frame is the same as the 1980 as this guy made it work sweetly
  • zombiescustoms
  • zombiescustoms's Avatar
09 Oct 2008 19:03
#241017
OK this was like the easist thing I did to my whole bike!!! Do a search, get the neck bearing sizes and call ALLBALLS and just do it!!
1979 KZ1000 drag/street fighter
1015cc stock internals for now, 39 flattys, GSXR frontend, ZX9 rear wheel with 6 over chromoly arm, just a budget beater!
  • steell
  • steell's Avatar
09 Oct 2008 19:48
#241023
I checked out a 77 KZ1000 with GSXR1000 front end and GS1100E dual shock swingarm last weekend.
Definitely had a turning problem, the guy made stops to keep the fork tubes from hitting the tank, and you aren't going to make any sharp turns with it :laugh:
  • PLUMMEN
  • PLUMMEN's Avatar
09 Oct 2008 20:12
#241028
pretty much same physically,that does lok pretty clean.B)
  • Z1109R Fin
  • Z1109R Fin's Avatar
09 Oct 2008 23:52
#241055
As usual Steel has a point there. Turning radius may become rediculous as it is in mine with a GSXR USD front and GSXR swing. Radisu becomes bigger due to fatter fork tubes and smaller off-set on tripples. But this is only inconvenient; makes handling on parkin lots, carage more intrestingOthewise swapping is not too difficult, making all brackets and fitting all needed parts is the issue.
Z1000R ´83...Slightly modified...
  • roy-b-boy-b
09 Nov 2008 16:12
#246518
The picture was on photo bucket. With work slowing down maybe i will get something done. I am at the point of wiring the bike. I have the ignition wired and need to wire the lights. Then tear the bike down and clean up the welds and paint the frame and reassemble.
This is a red neck conversion. I had to make all the rear brake brackets and the shifter linkage.
The bike still has the same wheelbase. Roy
  • ds390ss123
06 Dec 2008 10:05
#251030
OK!! Here is where I am at. Got 1999 zr-7 front end dry fitted on the bike. Used allballs for the bearings and stock zr-7 seals worked well. I do need to weld some stops on the frame but it seem its not going to be a problem at all.
