Center stand
  • patmann
  • patmann's Avatar
Re: Center stand
09 Sep 2008 11:03
#236345
AND with a center stand you can still use the stock Jardine pipes, or a Kerker!!! Done both, and at present using stock LTD pipes.
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: Center stand
09 Sep 2008 17:48 - 09 Sep 2008 17:48
#236404
From what I have been told, all of the 73-80 900 and 1000 center stands will fit, but might have a different tab or nub or whatever the thing is called that you put your foot on to put it down. For example, the one on the Z1-R is much shorter. If you're not worried about being model/year correct, any of them should do the trick.
As was mentioned, this type of lift works great too:
The Kaw List:
Last edit: 09 Sep 2008 17:48 by 79MKII.
  • sbulla
  • sbulla's Avatar Topic Author
  • 1980 KZ1000 LTD
Re: Center stand
10 Sep 2008 07:47
#236515
Patton wrote:
15 seconds for one weakling, two jackstands, and a pipe ---
Dude!...just thought I'd post and show you I tried your method and it works!
The rear tire is about an inch off the floor.
Here's the evidence...
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
  • sbulla
  • 1980 KZ1000 LTD
Re: Center stand
10 Sep 2008 07:48
#236516
...and here...
Thanks,
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: Center stand
05 Oct 2010 07:05
#404156
Neat trick!
Any tips for raising the front wheel?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • JMKZHI
  • JMKZHI's Avatar
Re: Center stand
05 Oct 2010 07:37
#404163
I made an engine block stand out of scrap pieces of 2x8s & 2x4s.
The 2x8 is the base & a couple of pieces of 2x4s are sandwiched together & screwed to the base.
As for the jackstands & pipe method, I'd probably put some padding of some sort on the pipe to keep from scratching the frame. Maybe some milk jug plastic or thick rubber sheet material.
Re: Center stand
05 Oct 2010 07:59
#404167
Kidkawie wrote:
Neat trick!
I just use a bottle jack under the front of the engine using a small piece of wood between the jack post and engine to protect the bottom of the engine. This works fine for small tasks like removing the front wheel. If doing extensive work on the front of the bike that might require pulling and banging on things (like removing the front forks and replacing the steering stem bearings) I park the bike in the center of a 4x8 sheet of 3/4" plywood and jack up the front end as described above. Then I run a heavy cargo strap through the rear of the bike above the swingarm / in front of the shocks. I then hook the 2 S-hooks on the end of the strap under the trailing edge of the plywood and take up the slack. By doing this, the bike is very steady on the centerstand and jack because the jack isn't the only support for the front. Even if the jack was removed (which I don't recommend) the strap will hold the rear of the bike down so the front won't fall. Ed
  • hocbj23
  • hocbj23's Avatar
Re: Center stand
05 Oct 2010 11:42
#404222
Or u can soend 35 bucks on a good paddock lift and get the bike up as far as the centerstand normally takes it with very little,if any effort--and it is very stable.bj
Re: Center stand
05 Oct 2010 14:16
#404248
Kidkawie wrote:
...Any tips for raising the front wheel?
Hidden among the above posts is this
Bonus tip --
With rear end lifted and being firmly held
in place by the pipe through frame resting
on tops of the jackstands,
May then use a standard floor jack or bottle jack
to lift the front end whereby entire bike is
up off the floor.
My method is to bore a shallow hole in a short
piece of 2x4 to fit snugly around the oil
filter bolt head. Then jack up against the 2x4
which is held in place by the hole fitment.
It is very stable and may be left like that
for as long as desired.
Having the bike entirely up off the floor allows
easily removing both wheels simultaneously
for tire changes, or other work.
Caution -- whenever front of bike is lifted
with front wheel removed, be sure to supplement
the floor jack or bottle jack with a stationary
back-up support to avoid having the bike's
front end collapse and fall to the floor
in event the jack should lose pressure.
Good Fortune! :)
  • IowaKZ
  • IowaKZ's Avatar
  • '80 G1 Classic
Re: Center stand
05 Oct 2010 17:27
#404326
I bought a center stand for my '80 G1 Classic, which is similar (I believe) to the LTD. the stand fits the tabs ok, but it seems too tall because it's hard to get it up (that's what she said :laugh: ) and when I finally get it on the stand, the rear tire is 2-3 inches off the floor. This is not a problems, but it's hard to lift.
I know, push down on the stand with one foot, while lifting with your hand. I was doing it one time and pulled a muscle in my calf.
I took mine off and plan to use it when I need to work on it and for winter storage.;)
1980 G1 Classic
Bettendorf, Iowa
  • JMKZHI
  • JMKZHI's Avatar
Re: Center stand
05 Oct 2010 17:51 - 05 Oct 2010 17:52
#404335
Maybe you could roll the wheels onto a couple of plywood squares, raising the wheels in relation to where the stand contacts the floor. If 3/4 isn't thick enough, perhaps a couple of pieces per wheel could be sandwiched together to raise it enough to make rolling it onto the stand easier.
Last edit: 05 Oct 2010 17:52 by JMKZHI.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Center stand
05 Oct 2010 18:12
#404347
oh the poor paint on those frames,you guys are killing me! :laugh:
