Handlebar grips?
  • Treeman
  • Treeman's Avatar Topic Author
  • 1984 KZ 700 A1
Handlebar grips?
05 Aug 2008 09:24
#230298
Anyone have a recommendation for a good grip. I'm considering a chrome variation.
Thanks
1984 KZ700 A1
2005 Harley Softail Springer Classic
Palmyra, NY
  • RonKZ650
  • RonKZ650's Avatar
Re: Handlebar grips?
05 Aug 2008 09:44
#230302
I tried a few over the years and they are all crap. Stay stock Kawasaki. They can still be bought.
  • coppertales
  • coppertales's Avatar
05 Aug 2008 10:53
#230316
Z1 sells a nice grip. However, in the Texas summer heat they become soft and tacky. The stock Kaw grips are hard to beat....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • JMKZHI
  • JMKZHI's Avatar
Re: .
05 Aug 2008 13:00 - 04 Dec 2008 07:30
#230334
del
Last edit: 04 Dec 2008 07:30 by JMKZHI.
  • Treeman
  • 1984 KZ 700 A1
06 Aug 2008 10:27
#230513
Thanks Guys,
My stock grips do not provide any anti-vibration relief. Are you guys talking about other grips Kawasaki offers?
Thanks
1984 KZ700 A1
Palmyra, NY
  • Z1R rider
  • Z1R rider's Avatar
06 Aug 2008 10:56
#230516
I have the "Grab On" grips on mine and they are a dense foam and do dampen the high frequency vibrations. I have the "super bike" ones on mine. They last around 30,000 miles if parked inside. If your bars vibrate bad, it helps to install weights in the bar ends too.
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
  • bill_wilcox100
  • bill_wilcox100's Avatar
06 Aug 2008 11:05 - 06 Aug 2008 11:30
#230518
I wanted to reduce the vibration to my hands when I first got my bike so I installed these '70's style grips:
www.z1enterprises.com/detail.aspx?ID=429
I have had mine for 3 seasons and they are OK but getting tired. However, at under $7.00 USD per pair one can afford to change them out any time.
How good are they? They helped me a lot, but remember that the handle bars are bolted down directly onto the upper trees without the benefit of any rubber isolation. This is different from some other bikes I've had and I can feel it.
Just wondering out loud if any members have found a safe way to isolate this vibration... other than tuning out the resonant frequency with weights/shot :dry:
Best of success. :)
PS
Treeman, would you add your year, model and location... it's considered very frienldy.
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Last edit: 06 Aug 2008 11:30 by bill_wilcox100.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
06 Aug 2008 11:27 - 04 Dec 2008 07:29
#230520
del
Last edit: 04 Dec 2008 07:29 by JMKZHI.
  • RonKZ650
  • RonKZ650's Avatar
06 Aug 2008 12:24
#230538
There's different problems with any grip. Soft rubber will wear quickly and turn your hand black and if ridden without gloves can cause hands to become a sweaty mess. Foam grips and other bigger diameter grips force your hand to grip something too large diameter to be comfortable. Any grip without some kind of ribs force you to have to increase grip to maintain throttle. Also any grip that does not have ribs of some kind keep any air gap between your hands and the grips at zero, so sweat away in the summer, sweat turns to slippery. So there are tradeoffs. Vibration is annoying, but less annoying to me than gripping a slippery grip or large grip, not to mention aftermarket grips are damn UGLY.
  • Vter Bob
  • Vter Bob's Avatar
06 Aug 2008 16:20 - 06 Aug 2008 16:21
#230566
I've had issues with carpal tunnel and the vibration drove me nuts. I put these grips on the 550 and use a pair of gloves with gel pads in the palm. I've found them to be very comfortable, not to big, they don't get slimy and the groves do let a little air through.
Plus my favorite part - I got them cheap. :laugh:
I've now put a pair on the 1000 and they are working great there also.
tinyurl.com/5kc97h
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
Last edit: 06 Aug 2008 16:21 by Vter Bob.
  • bill_wilcox100
06 Aug 2008 19:00 - 06 Aug 2008 19:01
#230582
Just an observation here... if you find that you need to maintain a dead-man's-grip on the throttle all the time and that its bothering your hand/wrist you may want to try what I did.
I changed out the OEM throttle spring for one with less than half the pull (cheap generic from Canadian Tire) and I added one of those cheap friction operated throttle controls. Of course, my cables were new and well greased as well.
Now my right hand is almost as relaxed as my left. Because I don't have to hold the grips so hard I don't feel the vibration as mush too.
Anyone else install this combination or install others?
Best of success. :)
Upgrades:
Montreal, Canada
Last edit: 06 Aug 2008 19:01 by bill_wilcox100.
  • donthekawguy
  • donthekawguy's Avatar
06 Aug 2008 23:26
#230612
I also use grab on. Matter o fact I had a call earlier that my new ones are in. B)
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
