Ebay master cylinder
  • patmann
  • patmann's Avatar Topic Author
15 Jul 2008 07:10 - 15 Jul 2008 07:10
#226259
Here's the deal, I bought a used 1977 1000 LTD front master cylinder off a guy on e-bay. It's a 5/8" bore :) just what I wanted / needed for $25.00 shipped. :) Too good to be true??
I asked if it had any problems like needing a kit, or ANYTHING. He claimed it worked fine, and pumped up great.
Well I got it, it feels like new, but only pumps out a small drible of fluid:( When I opened it up it had caked goop at the bottom of the cylinder. I rinsed it out and have tried and tried for at least 20 minutes anyway, and still it's no better. But when I put my finder over the brake line hole and pump it, I have a STRONG suction on my finger! I mean to the point it leaves a ring on the tip!
But still only a drible of fluid coming out.
So do I..
(A) Order a kit and try to rebuild it.
(b) Keep working it in hopes it comes out of it.
(C) Take it to my local Ski-doo shop ( I work there too )
and use the parts washer or ultra sonic cleaner.
(D) Write the guy and tell him it doesn't work and see
what he'll do about it.
(E) Put it on the shelf next to the other four in need of
kits I have and call it a day. And continue on my
hunt for the working 5/8" bore.
Thanks for any input, I have never rebuilt a master cylinder so that does scare me:unsure:
Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Last edit: 15 Jul 2008 07:10 by patmann.
  • mtkawboy
  • mtkawboy's Avatar
Re: Ebay master cylinder
15 Jul 2008 08:17
#226275
Typical Ebay deal. Id rebuild anything brake wise I got off there. You will waste more time & postage then the $25 will ever cover. I think thats the one that you need a real long pair of snap ring pliers to get in there far enough to get the snap ring out. The rest is fairly simple
  • patmann
15 Jul 2008 09:56
#226292
IF I rebuilt it or any of my others.. is there a place with a tutorial or step by step on it??
I'm kinda' slow ( I work for the State of Illinois ) so pictures are always a plus for me.;)
  • mtkawboy
  • mtkawboy's Avatar
15 Jul 2008 10:40
#226303
Not that I know of. A snap ring holds everything inside, remove it, remove the guts, hone the cylinder, clean with alcohol, apply lube and reassymble assuming the hole isnt all pitted up, bench bleed , install on bike with hoses and bleed system
  • bountyhunter
  • bountyhunter's Avatar
15 Jul 2008 12:40
#226324
My FSM has section drawings of both master cylinders. Not a step by step rebuild guide.
  • patmann
15 Jul 2008 12:55
#226325
Be gentle with me, I'm a virgin at this stuff:P
What size hone would I use? Is there one just for the 5/8"
master??
  • patmann
15 Jul 2008 12:57
#226326
bountyhunter wrote:
[My FSM has section drawings of both master cylinders. Not a step by step rebuild guide.[/quote]
Again, I'm slow but teachable..what the heck is a FSM??
  • RonKZ650
  • RonKZ650's Avatar
15 Jul 2008 13:14
#226330
If you haven't tried it, I'd install it and it might work. Hard to tell really without having the lines all hooked up.
  • patmann
15 Jul 2008 13:41 - 15 Jul 2008 13:42
#226335
I've changed out masters on many things in the last 51 years and never had one act like this ( that worked ). It just dribbles the fluid. Not even a little squirt.
I really don't like bleeding my dual front brakes either, so I'd prefer to know first..
But you think it might work huh..?
I'll ponder it, as I know you have put more miles than I have on.
The poor old gal only has 143,xxx miles on her.
Pat
Last edit: 15 Jul 2008 13:42 by patmann.
  • mtkawboy
  • mtkawboy's Avatar
15 Jul 2008 14:35
#226346
FSM = factory service manual. Correct snap ring pliers may be tough to find that will reach in there
  • RonKZ650
  • RonKZ650's Avatar
15 Jul 2008 15:05
#226355
I could be wrong definately. In all these years and Kawasaki's I've had a total of (2) master cylinder problems. If it's one of those round master cylinders, those are without a doubt hard to get the clip out of. If it's the newer trapazoid shape, those come apart with a simple screwdriver pry.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
15 Jul 2008 17:04
#226368
Take a look at some of these,Pat...
Master Cylinders
1977 KZ1000 A-1
