Police trees worth the hassle?
- steve3408
09 Jul 2008 20:47
Has anyone actually put the police triple trees on their KZ and made it all work ok? The fork tubes are like a mm or so different in diameter,and the axle has to be from the P model also,along with spacing for the fender mount, but is it worth all that hassle for just a little wider forks?
It sounds like a good upgrade to be able to use the wider tires,...but? is it worth the hassle and expense?
1980 KZ1000 A4(bought new),1979 KZ1000 MKII(bought new),1978 KZ1000 A (sold)1979 KZ1000 B LTD (sold)1976 KZ900 LTD (sold)1978 KZ750 twin (sold)
- StreetfighterKz
Re: Police trees worth the hassle?
10 Jul 2008 08:57
I put police (Kz1000C) frontend on my 1000. All bolt up stuff as far as the gauges and chassis goes. I swapped in a Zx11C front rim but that didn't require a lot of mods. I didn't notice a big difference over the standard forks but I don't push the bike all that hard do to lower ground clearence as a result of the smaller diameter front rim.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- darmahsd
14 May 2009 15:45
What diameter are the police forks? '84 GPZ1100 are 37MM. I'd like to do a conversion but rather make it period correct, old school. Just bigger fork tubes. Not all the work and hassle of way bigger modern, or USD. Something like when Honda first raced the second generation F bikes in superbike. They had skimpy 35MM forks. They swapped them out on Freddie Spencer's bike for 39 MM forks from the Gold Wing. I thought about KZ1300 forks, but they are leading axle and create their own set of problems. I'd like to know if there is anything out there that is around 40 MM that will go into the steering stem with little modification. I don't mind retaining the stock wheels and spec tires. Since I had this new, I've always been unhappy with the flex I feel from the 37MM forks and the premature wear of the valve springs in the anti-dive hardware. If this isn't doable this way, I figure it can't hurt to add a Tarozzi or ATK fork brace.
Stephen
Stephen
- Bdog
- Sweep the leg johnny!!!
14 May 2009 15:54
early nineties zx6e trees bolt up and the forks are 41mm. If you also get a set of trees from a 95-97 zx6r you get the adjustable forks and slab top yoke. Then have the stem pressed out and replace it with the one from the e model and done! I have all the parts is why I know and am still waiting to make the swap myself, but I have a lot of work in my front end now ('89 katana 750 with progressive springs and clip-ons) or it would be done already. Hope this helps. Oh they are conventional style forks.
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- kano
- Not Another Bloody Limey!
14 May 2009 16:06
gpz1000r 86 forks 40mm on my kz1000r before removing them for the busa front end, i honed out the original tree's to 40mm to take forks.
- Russ Jackson
14 May 2009 17:39
kano wrote:
That is a nice looking bike...Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- darmahsd
14 May 2009 18:10
kano wrote:
i honed out the original tree's to 40mm to take forks. quote]
Bdog,
Early ninties ZR6E looks like a good way to go.
The 40MM from the '86 1000R looks the easiest, if you're just boring out the stock clamps. I had considered that long ago and now actually see one in your bike, kano. Really nice, but I thought going that route might compromise the strength of the stock clamps after removing the material.
I guess you would know. If you've been riding it long enough, is that a concern?
Stephen
- kano
14 May 2009 18:22
i noticed no ill affects,
i was riding it to work for 11mths the tree.s seem fine,
im a big boy who's weight alone should have shown any potential problems in doing this which there was none i still have them too.
- StreetfighterKz
15 May 2009 04:19
darmahsd wrote:
I'm 98% sure the older police forks are 38mm.
Later, Doug
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
