Fork oil weight and level for Z1r
- kaw-62046
07 Jul 2008 21:20
I put in new fork seals and 10w fork oil in my Z1R.Front end seams to bottom out over big bumps.Does any know the oil level and if I change to heaver weight oil 30w? how many CC after removing oil from forks.
- Z1R rider
Re: Fork oil weight and level for Z1r
08 Jul 2008 05:24 - 08 Jul 2008 05:27
The level should be 17.4" from the top with the fork fully extended and the spring removed. (book calls for 10w oil) If it still bottoms (mine doesn't) you can raise the level by small (.5" at a time) amounts. Don't get the oil level too high or the forks will lose some of they're travel (and blow fork seals) when they hyd. lock without enough air space.
1978 KZ1000, Z1R
1999 250 Ninja race bike
Last edit: 08 Jul 2008 05:27 by Z1R rider. Reason: can't spell!
- PLUMMEN
08 Jul 2008 10:54
i like 30w synthetic motor oil 180-188cc with bone dry forks
08 Jul 2008 15:43 - 08 Jul 2008 15:46
Per FSM:
1978 KZ1000-D1 "Z1R" fork oil level using SAE10W20 should be 16.5" or 420 mm from top, fork fully extended, with spring left inside (i.e., spring not removed).
1979 KZ1000-D2 "Z1R-II", fork oil level using SAE10W20 should be 17.4" or 441mm, fork fully extended, with spring removed.
Putting 180-188cc into a dry fork, or 160cc into a wet fork, supposedly results in these levels.
An appropriately marked wood dowel makes a handy dip-stick.
Good Luck!
Good Luck!
Last edit: 08 Jul 2008 15:46 by Patton.
