Best way to cut wheel spacers?
  • toadson
  • toadson's Avatar Topic Author
16 Apr 2008 20:56
#207045
In order to finish my GS1100 swingarm swap, I need to cut down some 7/8" spacers for the rear axle. I've been trying to think of a way to cut down the spacers I have, as they need to be 11/16" length and cut as square as possible. I'm broke, or else I would turn to the machine shop to do it for me. I know there are people out there who cut down wheel spacers on their own, but I'm not sure how they do it and get a square spacer in the end. I have some tools available such as a cutoff wheel and air powered hacksaw, but neither is really practical to make a perfect cut. I'm interested in seeing some of the ways that any of you have cut down a spacer, without using something like a lathe (which would be nice to have). Let me know, because I want to ride my bike again! Thanks!
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
  • cmmman
  • cmmman's Avatar
Re: Best way to cut wheel spacers?
16 Apr 2008 22:47
#207068
When i was in school learning to be a machinist onr of the first projects we had involved squaring up a piece of stock that had been cut with a band saw using just a file. The filed ends had to be square w/i .010 over like 3 inches. Cut the spacer as close as you can and leave a little to file. Use a good square to check as go.
A sharp file can really remove metal if needed. Files only cut in one direction, but for heavy removal draw filing can work well and will leave a smoother surface.
or u could try a grinder with a flap wheel.
1977 KZ650B, modified.
  • FloridaBiker
  • FloridaBiker's Avatar
19 Apr 2008 19:17
#207702
I agree with the hand file approach.
Tip on technique: Set a micrometer or caliper to the correct thickness and use it as a "Go/No-Go" gauge. Check frequently as you file.
  • leboeuf
  • leboeuf's Avatar
21 Apr 2008 15:13
#208050
If you're going to try freehanding it with a hacksaw, at least make a jig to get your angle roughly correct.
  • TheTrout
  • TheTrout's Avatar
22 Apr 2008 09:26
#208208
I have not tried this yet, but I always thought you could put one of those metal cutting disks for your circular saw on a standard chop saw that you would use for wood. If you took your time I realy don't think it would damage the saw any and also it's aluminum, right? You should get a good square cut from a properly setup chop saw.
1978 KZ1000B2
  • Saki Jockey
  • Saki Jockey's Avatar
25 Apr 2008 19:11 - 25 Apr 2008 19:12
#209133
What part of the world are you in toadson? Maybe one of us with access to a machine shop could help?
Rob A.
550 A4
GTA,
Ontario, Canada
Last edit: 25 Apr 2008 19:12 by Saki Jockey.
  • tool maker
  • tool maker's Avatar
26 Apr 2008 20:16
#209356
I live in Lancaster,PA
Send them to me and I will face them to length for ya.
Or better yet, give me the dimensions and I'll send you new ones.
Doug. Machine shop and KZ owner
Lancaster, PA
82 KZ1000 M2, stage 3 jet kit, pods, 4 into 1 Mac, Accel coils & wires.
  • toadson
28 Apr 2008 22:31
#209958
I guess I should have updated this after I figured out a way to sand them down evenly. I wouldnt even know where to begin to explain how I did it, but now I have two spacers that are nearly perfect. I would have had the bike running with the new swingarm, but my chain was a bit too short. Got a new one on the way and it SHOULD be here tomorrow. My next quest is going to be finding some proper shocks, and then figuring ou a chain guard and the swap should be complete. Thank you for the kind offers, this is truly a great forum.
